1gm10 alarm - SailNet Community
 2Likes
  • 2 Post By aa3jy
post #1 of 8 Old 08-02-2014 Thread Starter
1gm10 alarm
Hi All,
When I turn on the battery the alarm sounds.
Start the engine... alarm stops, as it should.
Stop the engine ... alarm sounds and stays sounding.
This one is new to me, all was well until I changed the battery.
Also, the engine is showing a new tendency to stall when idling, when cold, and is slower to start, needing some throttle to get going.
Where should I start looking?
Captain Aubrey is offline
post #2 of 8 Old 08-02-2014
Re: 1gm10 alarm
Originally Posted by Captain Aubrey View Post
Hi All,
My, that is a puzzle. The VW diesels I had had a battery powered solenoid that acted as a fuel on/off valve, no hands on experience with Yanmars.
I can't think of why a new battery would effect fuel delivery unless you have an electric fuel lift pump? Perhaps you hit or dislodged a fuel line connection when installing the battery, allowing a minor air leak?
"Slower to start"? If your engine has glow plugs, maybe they are not getting enough current, maybe go over all electric connections to make sure they are clean & tight.
Once it is warm does it run properly? If so, it may be back to the glow plugs.
Interesting, let us know what you find.
Paul T
dabnis is offline
post #3 of 8 Old 08-03-2014
Remember you're a womble
PaulinVictoria's Avatar
Re: 1gm10 alarm
The alarm is oil pressure, should sound when you have power without the engine running although it may take a few seconds to sound after stopping. Maybe the new battery finally has enough juice to sound the buzzer?
As to the problem starting etc, sounds like the timing is off. Mine used to take several seconds, needed throttle on/off and so on, generally a bit of a pain to start. Adjusted the timing and it now starts in a second or two with no throttle at all.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #4 of 8 Old 08-03-2014
Re: 1gm10 alarm
It kind of sounds like the starting, rough when cold problem, started when he changed the battery? I am wondering if any other work was done at or near the time the problem started. I am assuming it started & ran OK before hand?
Paul T
dabnis is offline
post #5 of 8 Old 08-14-2014
Over Hill Sailing Club
smurphny's Avatar
Re: 1gm10 alarm
If you reversed polarity when installing the new battery, even momentarily, it may have fried the diodes in your alternator. I had this happen. The symptoms sound similar. Somehow after the alternator is shorted, a backfeed develops into the alarm circuit.
smurphny is offline
post #6 of 8 Old 08-14-2014
Re: 1gm10 alarm
Hi All,
Normal...look in you Yanmar shop manual,if you have one, explains the alarms
RichH and asdf38 like this.
aa3jy is offline
post #7 of 8 Old 08-15-2014
smurphny's Avatar
Re: 1gm10 alarm
Just turning on the battery should not activate the alarm circuit. I think that's the key piece of evidence. If the alarm is sounding before the key is turned to the ON position, there may well be feedback through the alternator to the neutral into the alarm buzzer. The problem is not at the sending unit.
smurphny is offline
post #8 of 8 Old 08-15-2014
Re: 1gm10 alarm
I suspect your key switch is shorted if the key is in the off position and alarm sounds.Test switch for continuity.
aa3jy is offline
Use of 1gm10 through the winter Zuma Diesel 5 11-20-2013 02:16 AM
Low rpm 1gm10 akbucki Diesel 20 08-09-2012 11:42 PM
Overheating Issues (1GM10) asdf38 Diesel 26 07-25-2011 03:16 PM
1GM10 Oil Alarm Issue asdf38 Diesel 3 12-27-2010 10:04 PM
1GM10 questions rperret Gear & Maintenance 7 06-17-2007 07:51 PM
