Tips on loosening screw - Page 2 - SailNet Community
 5Likes
post #11 of 26 Old 08-09-2014
Re: Tips on loosening screw
I'm quite familiar with impact torque units. When I taught shop metal 12 it was a popular lath project. They worked really well but it's OK if you have to buy your tools. Just giter done.
Capt Len is offline
post #12 of 26 Old 08-09-2014
islander bahama 24
newhaul's Avatar
Here is the tool I would actually recommend for most peoples tool kit does screws as well as uses 1/2 drive sockets. Impact Screwdriver Set with Case I have used mine on many jobs even to break loose over tightened lugnuts on a car
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #13 of 26 Old 08-09-2014
OPossumTX's Avatar
And after you break it loose using the impact driver, you can use the bit and adapter with your ratchet to back it out.
OPossumTX is offline
post #14 of 26 Old 08-12-2014 Thread Starter
I drilled out both screws with a special drill and was lucky not to ruin the threads.
The oil seal on the hand cranck shaft was leaking and I needed to remove the cover to replace it.
I have now replace the seal with a new one and hope this will stop the leak (The old seal looked OK to me).
carlager is offline
post #15 of 26 Old 08-12-2014
I think you got lucky, not hearing any cursing and all. What was the "special" drill?
John
ccriders is offline
post #16 of 26 Old 08-13-2014
Old as Dirt!
svHyLyte's Avatar
Did you try the impact drive or just move directly to drilling out the screws?
svHyLyte is offline
post #17 of 26 Old 08-13-2014 Thread Starter
I bought a DeWalt impact driver (had to bring my tool box up to date any way
The phillips notches were destroyed on both screws when using the impact driver. Cut a new one - which also broke.
Then there was nothing else to do than drilling out the screws. It was remarkably easy (and no cursing )
Below is a photo of the drill and the screw with the destroyed notch Tips on loosening screw-foto.jpg
carlager is offline
post #18 of 26 Old 08-13-2014
Old as Dirt!
svHyLyte's Avatar
Below is a photo of the drill and the screw with the destroyed notch Attachment 34337
Ah... FWIW the impact drive I referred to is manual requiring only a good sharp blow from a heavy hammer which tends to press the screw bit into the screw as well as applying the twist, which cuts down on the chance of buggering up the screw. With electric impact drivers, its sometime difficult to apply enough pressure to a screw head to avoid the problem. They do work well on bolts, however. N'any case, I'm glad you were successful and hope that resolves your leakage problem.
ccriders likes this.
svHyLyte is offline
post #19 of 26 Old 08-15-2014
FWIW, I was also told (and have not enquired further) that a lot of Japanese equipment did not use Philips screws. Electronics and camera equipment from Japan often used Reed-Prince and other screws that are very similar to Philips--but just different enough to mangle them. This is supposedly because Philips refused to license patents to "the Japs".
Dunno if that's all bunk, but I've learned that there's a lot of variation in what is and isn't a genuine Philips head screw, and the quality of the drivers.
FWIW
hellosailor is offline
post #20 of 26 Old 08-15-2014
Mermaid Hunter
SVAuspicious's Avatar
I can't speak to the patent issues. I can say that I have run into a lot of Frearson (also called Reed and Prince) screws on boats, particularly in good quality woodwork, including screws used to hold down the sole.
Frearson screws have a lot going for them: one bit fits all size screws and they are much less likely to cam out than a Phillips screw.
I'm a fan.
For more than you really want to know:
SVAuspicious is offline
Fear no screw! rbyham Gear & Maintenance 2 03-29-2014 04:28 AM
Loosening frozen SS bolts in Aluminum? do335 Gear & Maintenance 18 05-14-2009 01:36 AM
Screw up! Stillraining General Discussion (sailing related) 9 03-26-2008 07:57 PM
Inner shrouds "loosening"? pmoyer Gear & Maintenance 11 05-15-2007 09:20 PM
