197? Westerbeke on Perkins 4.107 Block - SailNet Community
post #1 of 1 Old 08-10-2014 Thread Starter
Working 197X Westerbeke 40 on a Perkins 4.107 Block. Hurth Gear Approximately 1995. Counter Clockwise Rotation for forward. Gear has less than 150 hours. Drive Saver. Custom Alternator Bracket supports dual alternators (only 1 comes with Engine). New Fuel Filter Assembly. New Fuel Pump. Fuel Injector Pump serviced approximately 5 years ago. This engine uses heat exchangers for cooling; one for the engine coolant and one for cooling the oil. Separate Oil Filter for easy servicing.
This engine works, but probably could use a rebuild; it overheats at very high R.P.M. This engine has been partially disassembled. The reason for overheating is confirmed due to interior scaling; nothing a good muriatic acid bath won’t cure. Rings are fairly good; little smoke on start up and no smoke during normal run.
LOTs of extra/spare primary parts: Spare Header Tank. Spare Heat Exchanger for engine cooling. Spare Oil Heat Exchanger. Spare Exhaust Manifold. Spare Water Pump (Internal/Coolant Water). Spare Oil Sump/Filter. Spare Oil Pump. Spare Injector Pump (Value $400). Spare Pulleys. Spare Fuel Pump Parts. Spare Rods (8).
LOTs of extra/spare miscellaneous parts: Thermostats, Header Tank Caps, Fuel Filters (4), Thermostat Gaskets, Valve Cover Gasket, Intake Manifold Gasket, Exhaust Manifold Gasket.
Service Manuals included. Pickup Only in Melbourne Florida area (Satellite Beach). Video available. $1500 or best offer.
attitudeadjustment1 is offline
Tags
4.107 , 4.108 , diesel , perkins , westerbeke
Westerbeke 4-107 MarkRoadley Gear & Maintenance 12 10-21-2013 12:50 PM
Westerbeke 4-107 trecksail Gear & Maintenance 6 04-26-2013 07:15 PM
Perkins / Westerbeke 4-107 vs. 4-108 Parts? BELLATRIX1965 Diesel 4 02-06-2010 01:07 PM
Perkins 4-107 trecksail Gear & Maintenance 9 02-02-2009 07:35 PM
Perkins 4-107 tjkassen Gear & Maintenance 2 11-02-2004 01:38 PM
