Stop cable - SailNet Community
 2Likes
post #1 of 12 Old 08-12-2014 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Stop cable
I'm wanting to relocate the existing stop cable off of the plywood hatch and a bit further forward, but can't for the life of me work out how to get the black 'T'-handle off without breaking it.
How are these things fitted? Is there a trick to taking one apart?
Thanks,
Cameron
Classic30 is offline
post #2 of 12 Old 08-12-2014
JimsCAL's Avatar
Re: Stop cable
Pretty sure its threaded onto a fitting on the end of the cable. Try soaking it in PB Blaster or something similar for several days. Vicegrips on the cable fitting and a wrench on the handle "should" break it free. Good luck.
JimsCAL is offline
post #3 of 12 Old 08-12-2014
Re: Stop cable
This looks like a Teleflex cable so there should be a small locknut behind the T handle. Use a 5/16" wrench and undo this locknut and then the handle should unscrew with ease.
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
post #4 of 12 Old 08-12-2014
Re: Stop cable
Not sure about PB Blaster, but I got some Locktite on a plastic fitting which dissolved the plastic threads. You may want to put some on a non-working surface of the handle to see if it dissolves the plastic.
Paul T
dabnis is offline
post #5 of 12 Old 08-12-2014 Thread Starter
Classic30's Avatar
Dock
Re: Stop cable
It makes sense that it'd be a threaded fitting and there is indeed a locknut which is easily undone, but when I go to 'unscrew' the handle I'm only twisting the internal cable.
So it should just unscrew?? I can't see any set screws or any other tricks.. that's why I'm asking. I was worried that it might have some fancy molded end and the last thing I want to do is break the handle. I'll try some WD-40 and have another go..
post #6 of 12 Old 08-12-2014
JimsCAL's Avatar
Re: Stop cable
As I suggested in my first post, try holding the cable with Vicegrips. That should allow you to apply enough torque to the handle to unscrew it.
JimsCAL is offline
The Following User Says Thank You to JimsCAL For This Useful Post:
Classic30 (08-12-2014)
post #7 of 12 Old 08-12-2014
Re: Stop cable
If no joy in taking the handle off. Disconnect at engine and pull it all thru. Re/ree the outer and push it back thru.
Capt Len is offline
post #8 of 12 Old 08-21-2014 Thread Starter
Classic30's Avatar
Dock
Re: Stop cable
After buying a pair of vice-grips (the one tool I didn't have but knew I would need eventually) I finally got around to having another crack at this.. seems it just needed that extra bit of encouragement:
All good. Job done. Thanks for your patience.
fryewe likes this.
post #9 of 12 Old 08-22-2014
JimsCAL's Avatar
Re: Stop cable
Good news! Glad my suggestion worked for you.
Classic30 likes this.
JimsCAL is offline
post #10 of 12 Old 08-22-2014
Learning the HARD way...
eherlihy's Avatar
Re: Stop cable
You didn't have Vice-Grips?
Next, you'll tell us that you don't have Duct-tape on board.
Dude, how can you possibly operate a sail boat?!?
eherlihy is offline
Yanmar stop cable: upgrade to electronic button? Alex W Diesel 15 11-20-2013 06:36 PM
help me stop the rocking YARDPRO General Discussion (sailing related) 10 06-20-2010 09:11 AM
Windless cable size, cable manufacture and battery type? SanDiegoChip Gear & Maintenance 25 02-19-2010 10:44 AM
How to Slow Down and Stop John Rousmaniere Learning to Sail Articles 0 08-03-2003 08:00 PM
How to Slow Down and Stop John Rousmaniere Seamanship Articles 0 08-03-2003 08:00 PM
