Diesel oil question - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Diesel This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree2Likes
  • 1 Post By MarkSF
  • 1 Post By aa3jy
Old 13 Hours Ago
S/V "MACKINAC"
Maine_bill is on a distinguished road
Diesel oil question
My Universal M-30 diesel calls for 10w-40 diesel oil. Locally I can only find 5w-30 or 15w-40.
Can I substitute for another weight oil??? If so which way do I go. Living and sailing in Maine.
Do I look around to find the right weight
Thanks
Bill
  #2
Old 13 Hours Ago
MarkSF is on a distinguished road
Re: Diesel oil question
All I can say is, I've been using Shell Rotella T 15w40 for the last 4 years in my Universal 5424, and the previous owner used it for about 10. I buy it from Walmart.
If you really want 10w40, Shell make Rotella T5, a more expensive synthetic blend, in 10w40. I can see the advantage being easier starting on very cold days, and you're in a colder climate than me.
Both are well-respected diesel oils.
Interestingly, I just fixed a noisy tappet in my Land Rover V8, with Rotella T. Took about 500 miles to work its magic.
christian.hess likes this.
1984 Bristol 31.1
Alameda, California, USA
  #3
Old 13 Hours Ago
new dad!
christian.hess is on a distinguished road
or delo 400....I stick with oils for the life of the engine or for the time I use said engine
switcing oils searching for the holy grail does no good and in some cases can cause excess sludge and or sediment
15-40 is fine in a 10 40 specd engine.
unless you are in freezing morning temps you are in the same temp range that calls for 10 40
good luck
1973 Islander 36 "resto" ALMOST there, and ready to SAIL!
  #4
Old 13 Hours Ago
aa3jy is on a distinguished road
A caution note about using synthetics in an older diesel engine..
Using synthetic oils in older engines
  #5
Old 13 Hours Ago
new dad!
yeah Im no fan of synthetics for an old inboard diesel
if anything stick to dino stuff the delo 400 and rotella are so similar its funny...they are heavy and have nice amounts of detergents and anti shearing qualities.
if you are worried about wear previous to your ownership you can add some zddp like stp, or marvel mystery oil(those are the only 2 I have used and recomend) and call it good.
again stick to the same oil for the life of your engine especially if you have access to the same oil in your area...unless you move to another climate your good to go with 15-40
NOW BE WARNED this is the beginning of an oil thread, and wars start easily as soon as someone says only use this dont do that and never do this etc...
be warned! jajajaa
  #6
Old 10 Hours Ago
hellosailor's Avatar
Plausible Deniability
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
Bill, 10W40 should be stocked at any auto parts store. And any gas station. If you don't see it and don't need to do the oil change today, any service station can order it in for you. That might mean buying a case (12 cans) but wtf, it won't go stale.
Usually you can go below the ##W end of the rating, a lower number just means easier starting in cold weather. And the higher number reflects typical operation, that's more important. If your engine calls for 40 and you use 30, it is under-protected in high temperatures. If you use 50, the oil stays too thick and you lose some economy and power. But if you are worried, the right oil certainly can be ordered in for you. Check a price versus mail order or Amazon just to make sure you're not being taken advantage of on that.
  #7
Old 9 Hours Ago
I do think it's a good idea to use a diesel-focused oil like Delo or Rotella T, not just any 10w40. They have more of the detergents and surfactants to keep all that soot in solution. They also clean up a dirty engine, given time.
1984 Bristol 31.1
You may post attachments
You may edit your posts
Question about oil viscosity in a diesel genset pyewackette General Discussion (sailing related) 4 09-04-2012 09:20 PM
Why have diesel oil tested? coreywoodworking Gear & Maintenance 8 12-13-2010 06:25 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Diesel Oil Change Question saurav16 Gear & Maintenance 14 10-15-2007 12:19 PM
Diesel Oil nauticalrich General Discussion (sailing related) 3 10-16-2002 02:36 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
