1GM10 won't run over ~2500rpm - SailNet Community
post #1 of 9 Old 08-22-2014 Thread Starter
Adrift
Here is what I know about the boat/engine:
-1gm10 w/410 hrs. Not sure of service history.
-boat sat from fall 2013 to May when I bought it.
-it had about 2/3 tank of diesel, I filled it in May and put fuel treatment in.
-I changed the oil, filter, tranny oil.
The engine starts and runs well, but won't rev over 2500rpm. It also surges a bit, at full throttle is remains at 2500rpm, and occasionally goes up to 3000 only to drop back down. Also, if I drop the revs, then 'gun' it, it will go above 2500 for a short time before dropping back.
I'm thinking some kind of fuel delivery problem....time to change the fuel filters? I drained the fuel filter today and fair bit of black particles came out....this also got air in the system so I know I have to bleed it next time.
Any advice/additional info. appreciated. Hoping it's not a big job!!!
1984 Watkins 25
Sassafras River, MD
XPatriot is offline
post #2 of 9 Old 08-22-2014
Remember you're a womble
PaulinVictoria's Avatar
Re: 1GM10 won't run over ~2500rpm
In neutral or in gear? In any case, def change out the fuel filters and bleed it properly, also make sure the air filter isn't full of junk.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #3 of 9 Old 08-22-2014 Thread Starter
Adrift
Hello. In drive.
To be honest I didnt think to do this in neutral.
The boat needs a bottom job, but was power washed and the prop was relatively clean.
1984 Watkins 25
Sassafras River, MD
XPatriot is offline
post #4 of 9 Old 08-22-2014
Try it in neutral as well, that'll tell you if the engine can at least rev to 3600rpm easily. Do you get any smoke when you try to push it past 2500?
Also, have you checked to see if full throttle at the lever actually gets you full throttle at the engine?
Orange Crush
1974 C&C27 MkII
post #5 of 9 Old 08-23-2014 Thread Starter
Adrift
All things I'll check next time in at the boat. Thx PV.
1984 Watkins 25
Sassafras River, MD
XPatriot is offline
post #6 of 9 Old 08-23-2014
I had this exact problem on my old 1GM (not the 1GM10) and I changed EVERYTHING, reset timing, adjusted valves, checked compression, clean prop, nothing worked. Finally hired a mechanic who pointed an IR thermometer at the exhaust and told me it was a partially clogged. I dont remember if I fixed it before changing the engine for a 2GM13. I even borrowed a strobe light to check the speed of the flywheel to make sure the tach was reading right.
The 1GM was just too small for an 8000 lb boat cuz it had only 6.5 hp.
Frogwatch is offline
post #7 of 9 Old 08-23-2014
My old Volvo MD17C has never managed to get beyond 2250 rpm when in gear.
Peak power I understand to be at 2500 rpm.
If I try to push it harder than 2250 rpm, it simply smokes a lot and there is no point.
I just live with it.
2250 rpm is about 8 and a bit knots.
Not too bad for an 11 ton ship with a long keel.
Rockter is offline
post #8 of 9 Old 08-24-2014
Mechsmith
Rocketer, you are over propped, or have a plugged exaust. If a diesel smokes more than briefly it's being overloaded. This will either "tulip" the valves or put a hole in the piston sooner or later.
I have seen it happen a couple of times in my farm equipmment repair business. It will happen when the wind is on your nose and all you want to do is get home and you won't even notice the smoke in time. Fix it! It will blow at the most inopportune time.
Seafarer 29 KCB
Mechsmith is offline
post #9 of 9 Old 08-25-2014
cheoah's Avatar
May be barnacles on yer prop. Don't take many to overload yer engine. When my boat sits I'm always underneath cleanin the prop before setting off. Clean every last one off....
cheoah is offline
Yanmar 1GM10 won't start Sometimesbrilliant Gear & Maintenance 16 08-01-2014 06:00 PM
Yanmar 1GM10 won't start. lawsonmitchell Diesel 15 08-08-2013 02:43 PM
Tohatsu 4hp 4 Stroke won't run on integal tank Ward H Gear & Maintenance 6 08-16-2012 08:59 PM
tohatsu 3.5 won't run without choking jshep Gear & Maintenance 64 08-04-2012 08:26 AM
Engine won't run. Solinoid Valve? Gummy Gear & Maintenance 19 10-25-2007 08:28 PM
