Partner shut off key on overnight run now engine won't run... - Page 3 - SailNet Community
 15Likes
post #21 of 53 Old 08-27-2014
Cruising at a snail pace
Re: Partner shut off key on overnight run now engine won't run...
Originally Posted by JRickW View Post
Here is what I will try this weekend:
1) Pull the alternator belt
2) Purchase a new electric fuel pump and rig it to pump from a clean can of diesel directly into the injector pump. That way, I bypass the filters and all lines up to the injector pump.
How does that sound? Any other experiments to narrow it down?
Definitely worth a try. But if the problem is damage to the HP fuel pump I would expect the problem to be too little fuel, but your description suggests too much fuel/bad burn.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #22 of 53 Old 08-27-2014
Lake Hack
Clarks Hill Windbag's Avatar
Air entry in fuel pickup system? No cracks, loose clamps, fossilized gaskets? Can you see small air bubbles being sucked into the fuel filter?
Does fuel system require a re-bleed after 30 seconds of running? Does any air come out of fuel system after it shuts down?
Had similar symptoms from a JD powered tow-behind air compressor. Could see air bubbles filling up filter, and it died after a very short run. Would restart, but sucked air back into system. Repeat until batt dies. Fixed by brazing crack closed in pickup tube.
Clarks Hill Windbag is offline
post #23 of 53 Old 08-27-2014
BTW - shut your raw water inlet valve while doing all these engine start/die cycles
Faster likes this.
Don0190 is offline
post #24 of 53 Old 08-27-2014
bljones's Avatar
Dumb question maybe, but why does the boat have an electric fuel pump? the YSB engines all have mechanical pumps. If the boat ran for 6 hours with the key off, I will assume that the pump is not wired through the switch. Is the pump currently working?
It's 5 o'clock somewhere:
bljones is offline
post #25 of 53 Old 08-27-2014
JRickW I agree with your plan.
I understand you only have soot coming out in the exhaust water and not black or blue smoke? The soot is probably just being washed out of the exhaust system and is inconsequential.
If you don't have dark smoke the engine is not overloaded so I come back to being starved for fuel. As Faster says we can't tell a good injector by observation (but sometimes a really bad one). I would pick up a new one for your next troubleshooting session too.
Good luck.
KBuckley is offline
post #26 of 53 Old 08-27-2014 Thread Starter
There is definitely NO smoke. Only the soot in the water.
It literally sounds (the engine noise) like fuel starvation to me as well. The engine does not react to the throttle and just sort of peters out as if I pulled the throttle to shut it off. I will do the experiments and double check for air in the fuel.
Thanks again.
JRickW is offline
post #27 of 53 Old 08-27-2014
I also have a ysb12 and it has an electric fuel pump. I would re bleed the system all the way to the injector and do it again if it stalled after starting. We're your battery(ies) dead after you discovered the key was in the off position?
Thunderbay is offline
post #28 of 53 Old 08-28-2014
This is a stretch but the throttle cable is not doing something goofy is it?
KBuckley is offline
post #29 of 53 Old 08-28-2014
I'm not sure I would bet it is the injector (it may be) ......
It's your boat, place whatever bet you like. I see you're not fessing up to the last cleaning, however.
Do you religiously use biocide in your fuel or purchase fuel with it? Nasties could be inside your injector.
Jeanneau 54DS
Minnewaska is offline
post #30 of 53 Old 08-28-2014 Thread Starter
I am very confident there is nothing inside the injector, it was stripped and cleaned. What I don't know about the injector is the pop pressure and volume.
The fuel has all been replaced.
It is possible that something is going on with the throttle/governor. I will look into it a bit more.
Yes the batteries were dead after the run. That's because when the key is off, there is no field current to the alternator so it doesn't produce any voltage. The other thing with the key off is the electric fuel pump doesn't work. My engine doesn't seem to have a mechanical lift pump.
JRickW is offline
1GM10 won't run over ~2500rpm XPatriot Diesel 8 08-25-2014 05:07 AM
1981 Evinrude 9.9hp 2str starts but won't run CarbonSink62 Gear & Maintenance 26 08-21-2012 07:41 PM
tohatsu 3.5 won't run without choking jshep Gear & Maintenance 64 08-04-2012 09:26 AM
engine starts but won't shut off jamesgmahoney3 Diesel 8 09-20-2010 07:19 AM
Engine won't run. Solinoid Valve? Gummy Gear & Maintenance 19 10-25-2007 09:28 PM
