Partner shut off key on overnight run now engine won't run... - Page 4 - SailNet Community
 15Likes
post #31 of 53 Old 08-28-2014
Re: Partner shut off key on overnight run now engine won't run...
Originally Posted by JRickW View Post
I am very confident there is nothing inside the injector, it was stripped and cleaned. What I don't know about the injector is the pop pressure and volume...
I'm really not intending to debate you. I'm make it my last input on the issue. The injector nozzle itself is measured in microns (one-millionth of a meter). It takes an imperceptible amount of stuff to screw it up. Without professional ultra-sound, etc, equip to clean it, I don't understand why you're so confident. Nevertheless, all the best with it.
oldfurr likes this.
Jeanneau 54DS
Minnewaska is offline
post #32 of 53 Old 08-28-2014
Learning the HARD way...
eherlihy's Avatar
Originally Posted by Don0190 View Post
Take the belt off the alternator and see if it spins OK, since the engine ran at higher rpms and died when you went to idle maybe the alternator is binding just enough to stall out the engine at idle.
This!
eherlihy is offline
post #33 of 53 Old 08-28-2014
Closet Powerboater
MedSailor's Avatar
I agree here. It takes specialized tools to clean an injector. Sticking a needle into the nozzle (which is what some people are tempted to do to clean an injector) will surely have damaged it if that is what was done.
Having said that, I vote for the alternator binding and causing resistance.
MedSailor
MedSailor is offline
post #34 of 53 Old 08-28-2014
The fuel has all been replaced.
It is possible that something is going on with the throttle/governor. I will look into it a bit more.
Yes the batteries were dead after the run. That's because when the key is off, there is no field current to the alternator so it doesn't produce any voltage. The other thing with the key off is the electric fuel pump doesn't work. My engine doesn't seem to have a mechanical lift pump.
Perhaps somewhere there is a mechanical pump in series or in parallel with the electric pump? Unless fuel will gravity flow from the tank I think you would need either a mechanical or electric lift pump?
If so, maybe they are interacting with each other. A drawing of how your fuel system is configured would be helpful.
Paul T
dabnis is offline
post #35 of 53 Old 08-28-2014 Thread Starter
I understand and appreciate your concern and I am not going to assume that the injector is good. I will, of course be wary of the injector and may in-fact end up replacing it. But I can assure you that I fully and carefully disassembled the injector, every part was cleaned and inspected under a microscope. Then each part was lubricated with light oil and reassembled. The injector on this engine is a rather simple mechanical affair. It is not like an auto injector with solenoid and extremely fine holes. It is a precisely machined pin which is held in the end cap hole by a spring. The fuel pressure is countered by the spring until the "pop off" pressure is reached. At that time, the pin retracts out of the hole in the end cap and the fuel escapes out of the hole.
Again, thank you for your assistance. I am appreciative all all comments and theories. Some ideas I had not thought of, some I had, and others I am reconsidering.
Keep'em coming!
JRickW is offline
post #36 of 53 Old 08-28-2014
After years of electric assist fuel pump ,no surprise that sudden demand to go it alone,the mechanical pump gives it up. weak return spring fail or suck air when before was all right ,Cam lobe is worn (or cam following arm) and didn't matter before. Love a mystery, let us know.
Tempest and bljones like this.
Capt Len is offline
post #37 of 53 Old 08-29-2014
Lake Hack
Clarks Hill Windbag's Avatar
+1
Alternator dragging enough to choke down engine at idle isn't realistic. Belt would slip, screech, or smoke.
Clarks Hill Windbag is offline
post #38 of 53 Old 08-30-2014
Captain
Night_Sailor's Avatar
Is the boat bottom clean?
Sent from my iPhone using Tapatalk
USCG 100 Ton Master
RYA Yachtmaster Ocean
Night_Sailor is offline
post #39 of 53 Old 09-01-2014 Thread Starter
A quick update:
It is not the alternator.
It is not the electric fuel pump.
It had no bubbles in the fuel.
I am most suspicious of the injector pump or injector so I have removed the injector pump. I have not inspected it yet. Hopefully I'll get to it tomorrow.
JRickW is offline
post #40 of 53 Old 09-01-2014
Captain
Is this a problem under load or present with no load? Black soot means unburnt fuel doesn't it?
USCG 100 Ton Master
1GM10 won't run over ~2500rpm XPatriot Diesel 8 08-25-2014 05:07 AM
1981 Evinrude 9.9hp 2str starts but won't run CarbonSink62 Gear & Maintenance 26 08-21-2012 07:41 PM
tohatsu 3.5 won't run without choking jshep Gear & Maintenance 64 08-04-2012 09:26 AM
engine starts but won't shut off jamesgmahoney3 Diesel 8 09-20-2010 07:19 AM
Engine won't run. Solinoid Valve? Gummy Gear & Maintenance 19 10-25-2007 09:28 PM
