Vented siphon break - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Diesel This is a forum dedicated to diesel engines and their applicable accessories.
Old 3 Weeks Ago
Classic30's Avatar
Once known as Hartley18
Classic30 will become famous soon enough Classic30 will become famous soon enough
Vented siphon break vent
Here's an interesting one:
Our engine vented loop/siphon break thingy is installed under the cockpit (as high up under there as is physically possible) and has a reinforced clear plastic hose attached to the side of it going off into the dark reaches beyond... at least it was until yesterday, whereupon after exploring said dark reaches I discovered the end of it draped over the exhaust pipe and not attached to anything.
There have been quite a few mods over the years to various things back there (including a new exhaust). Anyone know where this vent should be venting to? Does it matter much??
Thanks,
Cameron
"Honestly, I don't know why seamen persist in getting wrecked in some of the outlandish places they do, when they can do it in a nice place like Fiji." -- John Caldwell, "Desperate Voyage"
  #2
Old 3 Weeks Ago
Re: Vented siphon break
We don't have one on our current boat, but on our last boat the syphon break was plumbed into a cockpit scupper.
  #3
Old 3 Weeks Ago
RichH's Avatar
RichH will become famous soon enough
Need some pics; otherwise, all you'll get is guesses and speculations without them. ;-)
  #4
Old 3 Weeks Ago
Classic30's Avatar
Hmm... righto - I'll see what I can get on the weekend.
In the meantime, it looks something like this:
What I'm asking is where should the vent hose be piped to? 'Cockpit scupper' is a possibility...
  #5
Old 3 Weeks Ago
You need both venting and a place to dispose of the occasional dribble (depending on water flow and exhaust geometry) so I think the cockpit drain makes sense. Seems I've heard some discharging into the cockpit above the drain - in some cases may provide a 'tell tale' similar to outboards... and yet drain away right off.
The Following User Says Thank You to Faster For This Useful Post:
Classic30 (3 Weeks Ago)
  #6
Old 3 Weeks Ago
Classic30's Avatar
Thanks, Ron - that sounds sensible to me.
I've got a drain hose from the cockpit seat to the cockpit floor so I'll see what I can rig up in that.
  #7
Old 3 Weeks Ago
RichH's Avatar
Yup, most probably the clear hose goes to a cockpit drain.
  #8
Old 3 Weeks Ago
deniseO30's Avatar
Move over Joan Rivers!
the plastic one made by vetus that was on my boat failed. I only found it by investigating what the small hose was that came off of it and into a connection down hill to the exhaust hose about 2ft from the transom outlet. We replaced it with Groco bronze but I never did get around to connecting the vent side of it back on to the exhaust hose.
Denise, Bristol PA, Oday 30. On Tidal Delaware River, Anchor Yacht Club. New Website!
my current "project"!
The Following User Says Thank You to deniseO30 For This Useful Post:
  #9
Old 3 Weeks Ago
Classic30's Avatar
Interesting.. thanks, Denise.
From the look of the remains of a corroded copper tube hose-clamped to the loose end, I suspect that mine was originally plumbed to the exhaust hose also - but came away long ago before the exhaust hose itself was replaced.
It's nice to know it's nothing to lose sleep over, but it's on my list of things to fix.
You may post attachments
You may edit your posts
Exhaust siphon break jr438234606 Gear & Maintenance 11 06-17-2008 06:55 PM
raw water anti siphon/vented loop? deniseO30 Gear & Maintenance 16 05-28-2008 11:12 AM
Siphon through Sink? NbyNW Learning to Sail 1 06-01-2005 07:57 AM
Siphon break question graham1 Gear & Maintenance 2 11-12-2003 06:13 PM
leak from engine raw water siphon break i670684 Gear & Maintenance 2 08-11-2003 05:53 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
