Fuel filters: what's going on here?!? - SailNet Community
 1Likes
post #1 of 17 Old 09-04-2014 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Went to change out the filter (Racor glass-bowl type) today 3 weeks after dosing the tank with BC-250 Biocide against a light infestation of diesel bug and here's what the filter looked like:
Normal enough on top:
Cor blimey!
Sorry I didn't get any pics of the filter sitting on the bowl, but I wanted to clean up the mess in a hurry and didn't think to stop and take a photo.
Only the paint actually inside the bowl is affected. It looks for all the world to me like the paint on the outside of the filter cartridge isn't compatible with diesel fuel. Is this even possible? Could it be part of a faulty batch maybe?!?
I'm glad I checked it because a few flakes of paint were already sitting in the bowl ready to be sucked into the secondary filter... and it's only been three weeks since the last filter change.
Classic30 is offline
post #2 of 17 Old 09-04-2014
pdqaltair's Avatar
Re: Fuel filters: what's going on here?!?
The paint pealing is probably a result of the major ingredient (common in paint removers):
Diethylene glycol monomethyl ether >60%
Not a US brand, so I have noted tested it and don't know anything about it. Certainly the glycol ether will help with cleaning (also common in carb cleaners), but I'm not certain how all of the system materials will react.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #3 of 17 Old 09-04-2014
Must have been the biocide itself that attacked the paint.. an overdose perhaps?
Glad you caught it when you did.
Faster is offline
post #4 of 17 Old 09-04-2014
RichH's Avatar
Could also possibly be the result of the fuel oil containing amounts of reclaimed 'biofuel' made from used cooking oils. The chemical responsible would be the contaminant - oleic acid, a well know 'problem' in fuel oils made from and blended with reclaimed 'cooking oil'.
If such is the case, then you will also find that the 'gaskets' and O-rings made from BUNA or Neoprene would be 'softened'.
On most filters with this type of physical configuration, the 'sump' is on the upstream side of the pleat pack; therefore, such flakes and debris would be captured on the pleats, but not the 'dissolved' nor particulated debris that is much smaller than the ÁM rating of the filter media, but surely would help to 'choke' the flow of oil if and when they did break loose.
RichH is offline
post #5 of 17 Old 09-04-2014
Seems like a strange design, to have paint on a wetted area. Why would you do that? The cartridges for my Fram filter are bare metal.
MarkSF is offline
post #6 of 17 Old 09-04-2014
RichH's Avatar
These are probably made in China by Xingtai Shengkaiyuan Material Co a 'new' manufacturing (a private label / re-branding) firm attempting to penetrate the lucrative worldwide automotive filtration market.
Fleetguard Oil Filter (LF670/LF677) China (Mainland) Auto Filter
RichH is offline
post #7 of 17 Old 09-04-2014
Maybe look for a Wix substitute.
RichH likes this.
MarkSF is offline
post #8 of 17 Old 09-04-2014
JimsCAL's Avatar
That's the chances you take when using an off-brand replacement. You decide if it's worth saving a few $.
JimsCAL is offline
post #9 of 17 Old 09-04-2014 Thread Starter
Classic30's Avatar
Dock
That's possible.. since the only thing I did differently this time around is to add extra biocide to kill the diesel bug that's clogging the filters in the first place. How well it actually mixed in I'm not sure.
I've never heard of biocide attacking paint before.
Despite the instructions, in future I think I'll start adding biocide to the fuel in the jerry-can rather than directly into the tank - and consider filtering it into the tank rather than adding directly (regardless of how clean the fuel appears to be).
post #10 of 17 Old 09-04-2014 Thread Starter
Classic30's Avatar
Dock
That's a bit frightening, since there's nothing on the can to indicate where they're made (and I've never questioned why they're so cheap).
I notice they also make 'Volvo-brand' filters! Shiite.. I've been lucky so far but will need to be a lot more vigilant in future.
How much water in the fuel filters is Ok? MarkSF Diesel 13 10-15-2013 09:32 AM
2 micron fuel filters billyruffn Gear & Maintenance 12 12-14-2011 06:34 PM
fuel filters bog69 C36 0 10-24-2009 09:24 PM
Diesel Fuel Filters roline Gear & Maintenance 2 09-27-2009 02:33 PM
Diesel fuel filters ahoyjim General Discussion (sailing related) 0 01-06-2006 07:47 PM
