engine size?.... - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Old 2 Days Ago
Rockter will become famous soon enough
engine size?....
Guys,
Not my boat, but what engine size do you recommend for a 28 ft, long-keeled sailboat, displacing 4.5 ton?
I thought a 20 hp would do it.
Thanks.
Rockter
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 2 Days Ago
denverd0n's Avatar
denverd0n is on a distinguished road
Re: engine size?....
20 hp would be good for a 9,000 lbs. boat. The general rule of thumb is around 2 hp per 1,000 lbs. of displacement.
  #3
Old 2 Days Ago
BarryL's Avatar
BarryL is on a distinguished road
Hey,
My Newport 28, around 7000lb, came with a 16 HP engine. I had a 2 blade fixed prob. I thought the engine had plenty of power.
I would think that 16-20 HP would be fine for a boat up to 10,000 lbs.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
  #4
Old 2 Days Ago
deltaten's Avatar
deltaten is on a distinguished road
Send a message via Yahoo to deltaten
IMHO, that's nominal. Personally, I'd go a tad bigger; Justin case ya need to get out ta Dodge right smart
Given that most are not really labeled at. true,, normally use able HP; mebbe something in the 25-30 HP range?
Facing head-on or.building seas, nasty increasing wind on the nose, aand a need to get to that hole. quick? Mo'is better
Factor in the possibility of engine-driven adsons and your HP output quickly gets eaten up.
Plan Aheab
S/V Chrysalis
'80 Watkins 27
North East, MD
  #5
Old 2 Days Ago
Puddin'_Tain's Avatar
Don't call me a "senior"!
Puddin'_Tain is on a distinguished road
For a 9000 lb boat you could probably get away with a bit less power, maybe 14 to 16hp. But 20 hp wouldn't be terribly excessive, IMHO. It would probably be a good idea to take a long, careful look at the available engine space, and how you are going to get to the various bits when it's time to service the engine (filters, zincs, water pumps, priming gizmo, etc.). On many boats of that size a 20 hp engine would be a pretty tight fit and/or make servicing an almost heroic task. A slightly smaller engine might make things just that much more tolerable.
Typed on my Underwood Finger-Flight Champion portable typewriter (in triplicate, using carbon paper), sent to my basement laboratory via pneumatic tubes, transcribed by Minions on a Commodore 64 (complete with 5 1/4" single-sided floppy), and uploaded to the Internets via 14.4 kbit/s modem. Ain't modern technology grand?
  #6
Old 1 Day Ago
Thanks guys.
  #7
Old 1 Day Ago
Classic30's Avatar
Once known as Hartley18
Classic30 will become famous soon enough Classic30 will become famous soon enough
FWIW, my 6-ton classic was originally fitted with a Henry Meadows 25hp donk. 20 years later the owner upgraded that to a 35hp Peugeot. Fast forward another 20 years and it's fitted with a 40hp Volvo and I now find I can tow an S&S30 (~5 ton, I suppose) plus a Tumlaren (another 3 tons?) at hull speed without even hitting maximum revs.
So, methinks 20hp will be fine for your lightweight flyer.
"Honestly, I don't know why seamen persist in getting wrecked in some of the outlandish places they do, when they can do it in a nice place like Fiji." -- John Caldwell, "Desperate Voyage"
You may post attachments
You may edit your posts
Engine Size wallster Engines 10 10-13-2014 11:04 AM
engine size blarg21 General Discussion (sailing related) 20 10-28-2012 12:53 AM
Engine size on Pearson 34 needsanap Boat Review and Purchase Forum 8 07-14-2011 02:20 PM
Is bigger better? (Engine size) cclark Newport 2 03-06-2009 06:05 PM
engine size kms Gear & Maintenance 7 05-13-2005 08:38 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
