Fuel pump died - SailNet Community
post #1 of 12 Old 04-20-2015 Thread Starter
Fuel pump died
My fuel pump died over the winter and I'm looking for a alternative if possible.
I currently have this facet pump.
What are my options?
Pearson796 is offline
post #2 of 12 Old 04-20-2015
me at 67!
deniseO30's Avatar
Re: Fuel pump died
they have an internal strainer, did you know? I'd replace it with the same. or the "cube" by Facet. which I have (and a spare)
My last project!
My boat is sold!
deniseO30 is offline
post #3 of 12 Old 04-20-2015 Thread Starter
Re: Fuel pump died
There is an external strainer before the pump and then of course a fuel filter on the engine.
post #4 of 12 Old 04-20-2015
Maine Sail's Avatar
Re: Fuel pump died
But there is also the internal filter.
Replacing A Facet Fuel Pump Filter
Are you using a 2 micron primary filter? If so that can play a role in an early demise...
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
ccriders (04-25-2015)
post #5 of 12 Old 04-20-2015 Thread Starter
Re: Fuel pump died
I have not taken it apart. It gets warm when I tested it, but does not pump. It worked fine prior to winter, now it does not.
post #6 of 12 Old 04-20-2015 Thread Starter
Re: Fuel pump died
I may go with a $50 cube as opposed to this $100 part.
post #7 of 12 Old 04-20-2015 Thread Starter
Re: Fuel pump died
I pulled the strainer out and it was clogged thick... I bet the pump burned due to it. When you turned on the ignition previously you could hear the pump working. Now it does nothing.
I valuable lesson learned...
post #8 of 12 Old 04-20-2015
me at 67!
deniseO30's Avatar
Re: Fuel pump died
gas or diesel?
My last project!
My boat is sold!
post #9 of 12 Old 04-20-2015 Thread Starter
Re: Fuel pump died
Diesel... Its a Universal M4-30
post #10 of 12 Old 04-25-2015
Schooner Captain
UnionPacific's Avatar
Re: Fuel pump died
pop down to a local parts shop and pickup a fuel pump for a 1995 GMC diesel. Cheap, and lasts about forever.
UnionPacific is offline
Suggestions for a fuel pump? Capnblu Diesel 22 01-10-2011 10:53 AM
Fuel Pump HorizonHunter Atomic 4 4 08-05-2010 04:50 PM
Fuel Pump puff6022 Gear & Maintenance 4 11-28-2008 04:07 PM
Help, pump not getting fuel! MedSailor Gear & Maintenance 16 07-10-2008 09:02 PM
Fuel pump justified Gear & Maintenance 5 06-18-2007 07:25 PM
