Perkins 4.108m - SailNet Community
post #1 of 6 Old 04-28-2015 Thread Starter
Perkins 4.108m
I just removed a start/stop solenoid from my Perkins 4.108M. Thought it would be a simple task to replace, however after calling the parts department seems its not. I was told based on the serial number ED22195 they did not list a solenoid and it may have been added after. Would anyone know the part number that is needed?
Thanks in advance.
20pilot is offline
post #2 of 6 Old 04-28-2015
Senior Moment Member
SloopJonB's Avatar
Re: Perkins 4.108m
Don't have any specifics for you but my old 4-107 had a solenoid operated stop "puller" that mounted on a bracket bolted to a bellhousing bolt. Considering how similar the engines are I imagine it would work.
SloopJonB is online now
post #3 of 6 Old 04-28-2015
Closet Powerboater
MedSailor's Avatar
Re: Perkins 4.108m
Not exactly what you asked, but can you fit a manual pull stop?
Medsailor
MedSailor is offline
post #4 of 6 Old 04-28-2015 Thread Starter
Re: Perkins 4.108m
Sorry, there is no part (stop Solenoid) listed on the diagram in the manual. I called to ask a Perkins Dealer, it was not listed on their end either. So far the only thing I have found was this: Perkins 4 108 4 165 6 354 Engine Stop Solenoid 12 Volts for Boat | eBay
I was hoping to get OEM.
Thanks
20pilot is offline
post #5 of 6 Old 04-28-2015
Seņor Member
PorFin's Avatar
Re: Perkins 4.108m
Thanks
20,
That one's identical to what I have on my 4.108M. If it is not like what you have on your engine, you may need to make/have made a mounting bracket and the linkage rod between the solenoid and the injector pump.
________
'85 BYB Vagabond 39
PorFin is offline
post #6 of 6 Old 04-29-2015 Thread Starter
Re: Perkins 4.108m
Thanks for the help just placed the order!
20pilot is offline
Perkins 4.108M DIY Rebuild -- A Narrative PorFin Diesel 267 04-28-2015 01:18 PM
Perkins 4-108M Switch details pbanderson Introduce Yourself 4 04-05-2013 03:03 PM
Perkins 4-108M 50HP overheating. CharlieCobra Gear & Maintenance 19 10-12-2007 12:43 PM
Old Perkins 4-108 firemanbob Living Aboard 3 03-12-2005 07:55 AM
Perkins 4108 joluke Gear & Maintenance 4 02-23-2002 03:50 AM
