2QM20 Oil Change - SailNet Community
post #1 of 4 Old 10-19-2015 Thread Starter
No more curry buffets
Ritchard's Avatar
2QM20 Oil Change
Anybody know the secret to extracting the oil from a 2QM20? When I use my extractor pump dealio thru the dipstick tube, I can only get about a litre and a half. I usually warm the engine, remove this litre and a half, refill with clean oil, remove a litre and a half again to get as much dirty oil out as I can, then refill again. Of course I change the oil filter last.
How can I remove more oil?
Thanks
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #2 of 4 Old 10-19-2015
Re: 2QM20 Oil Change
When I use my extractor on my 2QM20 I have to pull the tube out several times during the operation and this sort gets the suction going again. It's one of those pump-up type of extractors and it seems to work just fine. Takes awhile though.
Froggy is offline
post #3 of 4 Old 10-19-2015 Thread Starter
Ritchard's Avatar
I've never in 4 years ben able to get more than the litre and a half. I keep pumping up the extractor, still no joy.
Ritchard is offline
post #4 of 4 Old 10-19-2015
As I said: I have to pull it out several times during the operation. I extract some and when it seems to stop I pull it out until it starts flowing again and then stick it back in. Pump it more. Repeat. And then I repeat some more until it is all out and all I hear is slurping. Just like a good milkshake! It is a slow process but it doesn't seem to take more than 10-15 minutes. Also I shove it around some to make sure I am getting to the bottom. Hopes this helps.
Froggy is offline
Oil Filter Yanmar 2qm20 Froggy Diesel 3 10-01-2013 06:19 PM
1978 yanmar 2qm20 fuel in oil. from gear and maint forum AUBERGINE Diesel 10 08-11-2012 01:45 PM
No oil pressure after oil change brob76 Diesel 30 10-16-2010 11:52 PM
Yanmar 2qm20 oil out breather Gerrit747 Diesel 4 09-24-2010 06:25 PM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
