MD11C Gauges - SailNet Community
post #1 of 6 Old 11-10-2015 Thread Starter
MD11C Gauges
I'm in the middle of replacing my gauges for a MD11C Volvo Penta on my Pearson 323. It appears all the senders are in working order. I'm replacing the tach with a Tiny Tach and I'll install a generic voltmeter. Those are easy.
Where I'm running into a problem is replacing the oil pressure gauge and temperature gauge. Currently I know their senders work. I've Googled everything I can think of to find out how to find a compatible gauge but I can't find anything. I realize I might need a new sender and gauge but I still donít know where to begin.
Any help would be appreciated. I have googled and googled including (site:Diesel - SailNet Community).
br3nt is offline
post #2 of 6 Old 11-11-2015
Re: MD11C Gauges
The senders must be matched to the gauges if you expect the gauges to read correctly.
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
post #3 of 6 Old 11-11-2015
Re: MD11C Gauges
While it's true that gauges and senders must match, if you're not worried about cosmetically matching the existing gauges, you can easily buy senders/gauges from any number of automotive or marine suppliers. There's nothing special about them except that they must have the right threads for the engine ports and the right temperature/pressure ranges. I just bought 4 complete sets of gauges for Yanmar engines from Defender for about $70 each with senders. About 2 years ago, I bought a complete oil pressure set made by Faze for $35.
svinshallah is offline
post #4 of 6 Old 11-12-2015
Re: MD11C Gauges
This might help:
http://faria-instruments.com/site_manuals/IS0085E.pdf
We recently used Faria gauges on a power boat we refit that had a Yanmar. We did need to change the temperature sender to match the gauge, we were OK on oil pressure.
I assume volvo would use the european resistance values, but I don't know for sure.
capecodda is offline
post #5 of 6 Old 11-13-2015 Thread Starter
Re: MD11C Gauges
Awesome. I was thinking it had to be more engine specific. I'll worry about matching threads and go from there.
Thanks for all the help.
br3nt is offline
post #6 of 6 Old 11-13-2015
JimsCAL's Avatar
Re: MD11C Gauges
Yes most engine manufacturers use industry standard instrumentation. As was noted, there are differences between European and US practice. I do know there is a big difference in the fuel tank level senders, but am not sure about the oil pressure and water temperature units. Worst case is you have to change those senders.
JimsCAL is offline
Md11c mccormick201 Gear & Maintenance 3 02-23-2012 05:23 PM
MD11C replacement kb7c Pearson 23 01-20-2011 08:39 PM
MD11C transmission LeroyNash Pearson 1 08-02-2010 05:06 PM
Volvo MD11C honeyjbr Pacific Northwest & Alaska 2 07-31-2008 08:08 PM
