Modern Yanmar Diesel Sat for 3-4 years - SailNet Community
 3Likes
post #1 of 24 Old 11-28-2015 Thread Starter
I recently acquired a fantastic boat. Sadly she has been un-attended for the past 3-4 years, as such hasn't been ran or maintained.
The hull was build in 1998 and the boat was registered in 05 so presumably its somewhere from a 1998-2005. It is a yanmar, and it has less than 20hrs on the clock.
What should be done service wise before attempting to fire her up aside from the obvious, drain and flush oil, coolant etc. replace with new.
Should injectors be pulled, maybe some sort of lubrication in the cylinders to prevent any damage on the first crank over?
Presumably a good idea to check / change raw water impeller to see if its brittle and no good.
I will post the exact model of the engine tomorrow after I get down to the boat.
Thanks!
Will
willdadd is offline
post #2 of 24 Old 11-28-2015
RichH's Avatar
Re: Modern Yanmar Diesel Sat for 3-4 years
"Any" internal combustion engine that has 'sat' for several years and that wasnt 'prepared' for long term storage, should be verified that the piston rings have not become frozen / stuck / rusted BEFORE attempting to start such an engine.
Simple procedure: remove injectors / spark plugs (or open the compression release on a diesel if it has one) and attempt to HAND TURN the engine ..... with large 'breaker bar' and socket attached to the crankshaft nose bolt. Gently, attempt to rotate the crankshaft; if it turns 'easily' then good, start the engine. If there is a lot of resistance to hand turning, then spritz in penetrating oil into the combustion chamber to free-up the piston rings in their grooves, let soak; then try to wiggle (do not use force) the rings loose. Keep soaking, etc. until you can 'wiggle' the rings free and ultimately be able to easily hand turn the engine over. For severely rusted/frozen piston rings, sometimes it can take a week or more of 'soaking', rocking/wiggling to free up frozen/rusted piston rings.
If you dont do this check, etc. or FORCE the engine to turn over with the starter, etc. you are at risk for breaking the piston rings.
krisscross likes this.
RichH is online now
post #3 of 24 Old 11-28-2015
aeventyr60's Avatar
Fresh fuel and fuel filters...
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #4 of 24 Old 11-30-2015
I would be more concerned about condensation that has formed in the engine as there may be a rust spec on the fuel injection pump rack. I suggest that after you have replaced the impeller and fluids, that you crank the engine over with the stop control activated to get the oil around the engine for about 10 or 15 seconds. Then start the engine with the air filter off the engine. Make sure that you have a piece of plywood that you can hold over the intake in case the rack is stuck. This will be the only way to stop the engine in a run away situation. If you are lucky, the engine will be just fine and you can control the RPM with the throttle lever (governor control) and all will be right with the world.
However, if the rack does stick and the engine wants to overrev, block the intake with the plywood, NOT you hand as you hand can get sucked in. After the engine has stopped, remove the injection pump and have it serviced at a fuel injection shop.
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
post #5 of 24 Old 12-04-2015
Schooner Captain
UnionPacific's Avatar
3-4 years? dont worry about it.
Fire it up. If the starter does not turn it, then you have an issue.
No damage can result from trying, and what can happen (valves sticking) would already have happened.
As I have been rebuilding mine the past year I have not started it.
UnionPacific is offline
post #6 of 24 Old 12-29-2015 Thread Starter
Thanks, thats exactly what I did, changed the oil, rolled it over by hand while decompressed.. no bad noises etc, had someone on standby in case she ran away, and then fired her up.. couple min of rough idle and she smoothed right out.. going to have a mech go over it with me so that I know what to check and maintain regularly.
BarryL likes this.
Will
willdadd is offline
post #7 of 24 Old 12-29-2015 Thread Starter
Little bit of clatter but I guess thats pretty common for these yanmars
Will
willdadd is offline
post #8 of 24 Old 12-30-2015
Check your valve clearances.
Sent from my iPad using Tapatalk
Keth
Boat Vinyl Lettering and Graphics
Bleemus is online now
post #9 of 24 Old 01-03-2016
asdf38's Avatar
Which engine is it? You can go on youtube and find audio of any of them.
My 1 cylinder 1GM10 makes a hell of a sound. I wasn't 100% sure it was normal until I heard another one from across the dock once. I knew instantly they had the same engine.
asdf38 is offline
The Following User Says Thank You to asdf38 For This Useful Post:
willdadd (01-03-2016)
post #10 of 24 Old 01-03-2016
Skipper Jer's Avatar
When our 2gm20 fires up it runs for about 30 seconds (haven't put a stop watch on it) then sounds like it loads down. Turns out that is exactly what happens, the alternator starts putting out current around 30 seconds after startup. Ours also has clatter sounds.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
Starting a diesel that sat for 18 years. Skipper Jer Diesel 36 09-27-2013 08:36 AM
What check on diesel that's been sitting for 2-3 years. kwaltersmi Gear & Maintenance 13 07-02-2013 10:15 AM
Starting a diesel that sat 2 years CapnBones Diesel 15 05-12-2011 06:44 AM
Diesel sitting in tank for years oft Gear & Maintenance 12 12-05-2007 10:36 AM
How to?? get weather reports via sat email and sat phone at silentfaith General Discussion (sailing related) 0 01-16-2002 02:54 PM
