1980 Universal M-35 parts availability? - SailNet Community
post #1 of 12 Old 12-03-2015 Thread Starter
Heading to look at a boat early next week. It has a Universal M-35.
Am I looking at a repower or are parts for these old beasts still able to be found?
Sent from my iPad using Tapatalk
Bleemus is offline
post #2 of 12 Old 12-03-2015
krisscross's Avatar
Re: 1980 Universal M-35 parts availability?
No shortage of parts and fairly reasonable prices: Parts for Universal M-35
Plato
krisscross is offline
post #3 of 12 Old 12-03-2015
BarryL's Avatar
Hey,
That engine is based on a Kubota diesel tractor engine (I believe). Many parts are available from the Kubota dealers at MUCH lower cost than from a boat place. For example, I needed to change the thermostat on my M25 engine. It was $10 from the kubota dealer and $50 from Marine Diesel Direct. You can get glow plugs, starters, fresh water pumps (not raw water pumps) and lots other parts from the tractor guy.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #4 of 12 Old 12-03-2015
Stu Jackson's Avatar
It's a Kubota tractor engine. Google equivalent parts and save $$.
Engines 101 - The BIGGEST & BEST collection of M25 Series Universal Engine Information on the Internet, plus some M35, too
Diesel Engine - c34.org
Good luck on the boat.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 12 Old 12-03-2015
The parts that do tend to be expensive are the ones that are peculiar to the marine version - raw water pump, heat exchanger, and especially the exhaust manifold, which is currently available for $1700 online. At least it's available - they are not for my Universal 5424. This is not intended to put you off buying it, but rather to encourage you to inspect these parts carefully.
MarkSF is offline
post #6 of 12 Old 12-03-2015 Thread Starter
Thanks guys. Remember delivering a couple of boats with these in the 80s and never had a problem with em. Just didn't know if they were still part worthy.
That exhaust manifold will get some extra attention on Monday. Thanks!
Bleemus is offline
post #7 of 12 Old 12-03-2015
JimMcGee's Avatar
Bleemus,
Pull the dipstick. On most Universals the equivalent Kubota engine number is stamped on the dipstick. That's the number you need for ordering parts from the local Kubota dealer.
And if it needs motor mounts, forget the stock Universal mounts, go with the Vetus mounts, one size up from the mounts recommended in their size chart (based on engine weight) and she'll purr like a kitten. There's more on mounts on the Catalina 34 site.
Mark, you'd have to check the bolt pattern but you can probably use the exhaust manifold from the 35B at $725.
If the boat you're looking at is a Catalina check the joint where the exhaust hose connects to the water lift muffler. This is a common point of failure on older boats if the stock hose hasn't been replaced with an offset "hump" hose.
Also if the boat is 20+ years old check the rear corners of the oil pan for rust through. Depending on how the engine is mounted in the boat replacing the pan may require lifting the engine clear of the beds.
Jim
95 Catalina 30 Island Time
ďThe sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #8 of 12 Old 12-03-2015 Thread Starter
Thanks Jim! All great tips! Not a Catalina but great advice all around. Much appreciated.
Bleemus is offline
post #9 of 12 Old 12-03-2015
The parts that do tend to be expensive are the ones that are peculiar to the marine version - raw water pump, heat exchanger, and especially the exhaust manifold.....
Partially true. It is rare for an exhaust manifold to break. I haven't heard of one in 17 years.
The raw water pump should be an Oberdorfer, not a crappy Sherwood, and are available at Depco Pump Company for a reasonable price.
HXs can be found from Seakamp in Seatlle. $250.
All of this is covered in my last link.
post #10 of 12 Old 12-03-2015 Thread Starter
Thanks Stu! Added to my notes. All good info.
Bleemus is offline
Universal to Kubota Parts list? seaner97 Diesel 63 10-19-2015 02:33 PM
Universal 5424 vs 5416 parts Maine_bill Diesel 8 01-26-2014 11:44 PM
Universal Atomic Parts Dave_E Diesel 5 09-04-2013 10:01 PM
Farymann Diesel availability of Parts - repair manuals ChuckA Diesel 4 02-14-2011 05:30 PM
Source for Universal diesel parts? pegasus1457 Diesel 6 06-28-2010 05:10 PM
