3208 engine idle issue - SailNet Community
post #1 of 3 Old 06-14-2016 Thread Starter
My uncle has a trawler and the CAT 3208 engine is having an idle problem. As he was taking the baby out, it was experiencing a rough idle, but stops if it goes around 1000 rpms. That's not normal right, to go up to that much? what can be the cause?
fishandships is offline
post #2 of 3 Old 06-17-2016
al brazzi
Re: 3208 engine idle issue
I would look for air leaks in the system. I had a filter leak and would suck enough air so my 2 cly would not idle. The leak was small enough where it wouldn't affect operation in higher RPMs. The important thing to understand is the return will move enough fuel back to the Tank at the higher speeds to flush that air out. There was another poster who just went through the same thing and he found a brand New shut-off valve at the Tank leaking but it was under Vacuum so no wet spot. Read to see his test, pretty smart solution.
Yanmar 2GMF Fuel Mystery
albrazzi is offline
post #3 of 3 Old 06-17-2016
Not too many sailboats have 3208's. You will do better asking elsewhere like thehulltruth.com or even better, boatdiesel.com.
chuck53 is offline
Engine Starting Issue Fau Gear & Maintenance 11 12-30-2015 11:27 AM
About to buy, nagging engine issue - seeking advice planetminder Diesel 57 09-27-2014 04:39 AM
Engine over temp at idle H and E Diesel 17 03-13-2013 10:17 PM
Westerbeke W30/4-91 Idle Screw Assembly Needed, or engine for parts Reklobe Diesel 5 03-07-2013 12:05 PM
Gas engine won't idle kwaltersmi Gear & Maintenance 21 05-18-2011 04:08 PM
