Perkins 4.108 surging at idle - SailNet Community
 1Likes
post #1 of 13 Old 09-15-2016 Thread Starter
paulopinto's Avatar
Hi all,
This engine starts fine but immediately goes to very high revs. The only solution is to shut it down immediately.
What happened before:
I recently replaced primary and secondary fuel filters and engine oil.
The engine started fine and then after a few minutes started reving and died.
I proceeded to bleed the system and check all lines for signs of an air leak since the engine wouldn't turn on at all. After a long troubleshoot and many bleeds I got it started but this time it goes to very high revs and won't idle.
At that point I called a mechanic which pointed that it's an issue with the injection pump. We pulled the pump and took it for servicing. Now the serviced pump is back and the engine keeps on doing exactly the same thing. Last thing I did was to hook a clean fuel tank directly to the lift pump inlet. Nothing yet!
I'm running out of ideas, anyone?
Thanks in advance.
paulopinto is offline
post #2 of 13 Old 09-15-2016
al brazzi
Re: Perkins 4.108 surging at idle
Did you do all the work yourself with the mechanics recommendation. Sometimes its best to have them do the work at least if that doesn't fix the issue there is some dialog. Being a mechanical guy myself there is a distinction between work and advice, and that can work for or against you if you know what I mean.
albrazzi is offline
post #3 of 13 Old 09-15-2016 Thread Starter
paulopinto's Avatar
I did the filter portion and the first bleeding. The work related to the fuel pump was done by a mechanic.
post #4 of 13 Old 09-15-2016
krisscross's Avatar
When you replaced the engine oil, did it look normal?
Some ideas to check here: https://en.wikipedia.org/wiki/Diesel_engine_runaway
Plato
krisscross is online now
post #5 of 13 Old 09-15-2016
Senior Moment Member
SloopJonB's Avatar
Not to be too obvious but have you checked your throttle cable to be sure it's releasing all the way? Is the return spring still "springy" and not stretched?
SloopJonB is offline
post #6 of 13 Old 09-16-2016 Thread Starter
paulopinto's Avatar
Engine oil looked normal and the throttle cable seems to be working fine.
post #7 of 13 Old 09-16-2016
Master Mariner
capta's Avatar
Way too many "mechanics" these days are just 'parts changers', without any real knowledge or experience at identifying a problem. They just keep changing (or in this case rebuilding) parts until they get lucky, at the customer's expense.
I would call Transatlantic Diesel in Va. (Google TAD) and see if you can get one of their engineers to point you in the right direction. Once you have that, call this "mechanic" back and tell him he didn't solve your problem and either do so or refund your money.
It does sound like an injection pump issue to me, IF your cables are not at fault, so perhaps it didn't get properly repaired at all. But take your manual, or any pics of a 4.108 and see if you can see any discrepancies in the connections.
I once had an mechanic hook up an injection pump backwards after a rebuild, attaching the fuel feed to the return and vice versa, but he could be forgiven as they were experimental Mercedes engines and whoever mimeographed the temporary manual, put that particular pic on the page backwards. That one caused a lot of consternation on both sides of the Atlantic for a couple of weeks before someone realized that the pic was backwards. Small thing; huge, expensive problem.
Good luck with yours.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #8 of 13 Old 09-16-2016
Sounds a bit like the problem auto engines can have when the carb linkage over centers and works backward at high revs till shut down if you're quick. Not a likely but but easy enough to cross of the list. Once saw a Detoit D stick its governor shaft . Wasn't pretty. Sucking air at the filter or pump ??
Capt Len is offline
post #9 of 13 Old 09-17-2016
al brazzi
The detroit GM Diesels on our charter Boats had a remote control trap could you could pull to shut off the air supply I never had to deploy but it was the only way to shut the Motor off in a true overrun. If the OPs Perkins can be shut down by the fuel then I think this can be ruled out, but it is a real problem though you need to talk to a LOT of people to find someone it has happen to.
albrazzi is offline
post #10 of 13 Old 09-17-2016
al brazzi
That's good if he can't sort it out get another mechanic. The part is the problem if you deal with a top notch shop they have ways of handling that but costs more by the hour for that service.
albrazzi is offline
Old Perkins 4-108 firemanbob Living Aboard 5 08-15-2015 04:06 PM
c30TR with perkins M30 idle dan8152 C30 0 08-28-2013 03:13 PM
Perkins 4.108 jamesjle Diesel 6 03-19-2013 11:07 PM
Perkins 4-108 bnskramer Gear & Maintenance 9 05-27-2008 07:37 PM
Perkins 4-108 sailaway50 Gear & Maintenance 1 01-19-2006 07:55 PM
