Yanmar 3GM30F low RPM in forward - SailNet Community
 5Likes
post #1 of 32 Old 02-05-2017 Thread Starter
bigdogandy's Avatar
Dock
Hey friends - have a puzzle I'm trying to solve and would like some help......my engine starts up easily and runs great in neutral - smooth and quiet and will rev to 3,000 RPM easily; in reverse runs smooth and will rev to about 2,800 RPM; in forward, however, will only rev to a little under 2,000 RPM.....generates some white / grey smoke at that point but not excessive.
Transmission is Kanzaki KM2P, fluid is topped up and clean. All filters are new.
The problem has developed over the last 6 months or so.....first noticed it when coming in at the end of the day when the engine felt like it was losing some power in forward. Has gotten progressively worse since then.
Any thoughts on cause or things to check out?
Thanks.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
Last edited by bigdogandy; 02-05-2017 at 05:09 PM. Reason: changed "neutral" to "reverse"....thanks hellosailor!
bigdogandy is offline
post #2 of 32 Old 02-05-2017
Re: Yanmar 3GM30F low RPM in forward
Could be a plugged exhaust mixing elbow.. in neutral there's no load and less exhaust volume.
Faster is offline
post #3 of 32 Old 02-05-2017 Thread Starter
bigdogandy's Avatar
Dock
Thanks Ron - had cleaned the elbow when the problem first appeared, but maybe I didn't get it all the way cleaned out. Will take another run at that. Seems curious to me the problem only seems to occur in forward, though, and not reverse?
Andy
Key Largo
1981 Endeavour 32
- Wendell Berry
post #4 of 32 Old 02-05-2017
overbored's Avatar
Sounds like it is starving for fuel while under load. How many hours on the fuel injectors ? have you replaced the engine fuel filter? how old are the fuel lines? algae in the tank and fuel lines? fuel pickup tube in the tank has blockage?
"GOLD RUSH" PRINDLE 16
overbored is offline
post #5 of 32 Old 02-05-2017
overbored's Avatar
only in forward? what type of prop? fixed or ?
post #6 of 32 Old 02-05-2017
"progressively worse"
Barnacles on the prop? (Yum, bouillabaisse!)
hellosailor is offline
post #7 of 32 Old 02-05-2017 Thread Starter
bigdogandy's Avatar
Dock
New filters all around, but haven't checked the tank lately for scummage.... Will do that also. Fuel in the racor looks, clear for what that is worth. The injectors have at least 600 hours, as that is how many I've put on the engine over the last 9 years.
3 blade fixed prop, more than 2 years since last haul and paint but I clean it occasionally. Not pristine but not too bad, either. If it were the props wouldn't that affect reverse as well as forward?
Going below to clean to elbow now....love the boat yoga poses this boat makes possible in doing this operation!
Andy
Key Largo
1981 Endeavour 32
- Wendell Berry
post #8 of 32 Old 02-05-2017
" If it were the props wouldn't that affect reverse as well as forward?"
Presumably, but I didn't see you mention reverse at all?
The only thing that would affect performance "in forward only" would be a transmission problem. A fouled or unfouled prop would have the same (lack of) effect in both gears. Uless someone taught the barnacles to sing in harmony.(G)
bigdogandy likes this.
post #9 of 32 Old 02-05-2017
What fluid and at what fill level did you use?
aa3jy is offline
post #10 of 32 Old 02-05-2017
al brazzi
You are not trying to go hull speed in reverse so it is very different, plus pitch is different on a fixed prop in reverse. I would clean real good and see what you get.
albrazzi is offline
Tags
yanmar 3gm
Yanmar 3gm30f low RPM at idle carlager Diesel 10 10-11-2015 02:40 AM
yanmar vibration at low rpm 17spyglass17 Diesel 2 03-04-2014 12:42 PM
Yanmar tach reads low rpm malyea Gear & Maintenance 11 06-05-2013 08:38 AM
Yanmar stalls at low rpm markgoldfarb Diesel 2 06-26-2011 09:48 AM
High RPM = slipping out of forward??? olysailor Atomic 4 10 06-21-2008 09:24 AM
