gas station diesel - SailNet Community
 11Likes
post #1 of 28 Old 6 Days Ago Thread Starter
gas station diesel
My dock does not have a diesel pump. Is the gas station diesel the same as you would get at a dock? Thanks
thumper53 is online now
post #2 of 28 Old 6 Days Ago
Master Mariner
capta's Avatar
Re: gas station diesel
Pretty much the same stuff, give or take a few additives. Taxes are higher of course, on road diesel.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #3 of 28 Old 6 Days Ago
Really? I suppose it depends on where you are. Our marina diesel costs a lot more than that at local gas stations.
Diesels are not too particular about what they feed on. Only thing I would do, is add a diesel treatment like Biobar if fuel will sit in tank for any length of time. https://www.jamestowndistributors.co...ct.do?pid=3779
FreeAgent is online now
post #4 of 28 Old 6 Days Ago
4arch's Avatar
I hear this every time this topic comes up but have never actually seen it translate into lower prices for marine diesel in the wild. Marina pump prices are almost always within a few cents of landlubber fuel stations at best, and considerably higher at worst. Has to come down to volume canceling out the tax savings. The truck stop near my marina probably sells more road diesel in a day than the nearest fuel dock sells in a month.
4arch is online now
post #5 of 28 Old 6 Days Ago
Marina gas/diesel is ALWAYS higher than the corner fuel stations, usually quite a bit higher. But others are right, when you buy marina diesel, you are paying less in taxes.
Catalina 34
chuck53 is online now
post #6 of 28 Old 6 Days Ago
The OP does not have a bio -- no location and no boat.
Kind of presume that it might be sailboat, tho. Hope he "uncloaks" and puts this info in.
If buying diesel in my sailing area, northern Oregon, we look for a source of "off road" diesel, preferably from a marine fuel dock. Price is usually higher than vehicle-intended fuels, but then there is very little sales volume in comparison. Local fuel dock owner tells us that obtaining "straight diesel" is getting more difficult each year and one of these years he (and everyone else in our geographic area) may not have an affordable source. (sigh...)
The other (big) reason is that the formulation is different - less additives.
Unlike your vehicle, that will use up fuel rapidly, the various chemicals in diesel fuel can theoretically have time to settle out when your boat is parked for six months a year. While I doubt that the contents of the tank really look like a petroleum version of a "tequila sunrise" after time passes, I have no interest in testing that theory.
I do add Biobor at each fill up, altho if on delivery and we are going to use up the tank in a day or three I skip that additive.
All risks are relative, so I worry more about getting some water in my delivered fuel than the exact blend of diesel.
olson34 is online now
post #7 of 28 Old 6 Days Ago
As a point of further discussion by us board of experts , what are our thoughts about the use of "stove (heating oil) especially in older tech diesels. ? Adding lube oil to fuel ?
Capt Len is online now
post #8 of 28 Old 6 Days Ago
bristol299bob's Avatar
Road diesel is dyed yellow and when you buy it you are paying road taxes
Marine Diesel (I suppose more accurate is "off road diesel") is dyed red. You are not paying any "road taxes" when you buy it, but I find it's usually more expensive anyway.
Some terrestrial gas stations near me have a separate diesel pump with "off road" diesel, intended for boats and "off road only" vehicles. no taxes added and its cheaper than their "road diesel".
I'd say that it's more important to get fresh. clean fuel than to save a few bucks. I used to be at a marina that had a sketchy fuel dock. Back then I would fill up from Jerry cans with "road diesel". Now I have easy access to a fuel dock with pretty high turnover so I fill up there.
Barquito likes this.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #9 of 28 Old 6 Days Ago
JimsCAL's Avatar
One difference is that marine diesel is dyed while the fuel from the local service station is not. The other is that many marine fuels have special additives that the other will not. Not a big issue if you add them yourself. Here's what ValvTect says about their marine diesel fuel.
"ValvTect Marine Premium Diesel contains BioGuard micro-biocide and is formulated to keep the fuel free of bacteria, fungi and algae that plug fuel filters, cause corrosion and can shut the engine down. ValvTect Marine Premium Diesel also contains ValvTect's Diesel Guard Heavy Duty Marine Diesel Additive, which prevents and cleans up injector deposits that cause loss of power and poor fuel economy. Fuel economy tests indicate improved fuel economy up to 13.6%. ValvTect Marine Premium Diesel also contains cetane improver, fuel stabilizer, lubricity improvers and moisture dispersant that prevents wear, prevents sludge and significantly extends the life of fuel filters."
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #10 of 28 Old 6 Days Ago
overbored's Avatar
Advertising hype, they all do it, the diesel auto/truck brands claim the same type of additives to make your engine last longer and run better and get better fuel economy.
"GOLD RUSH" PRINDLE 16
overbored is online now
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Gas vs. Diesel mikekomm Diesel 14 10-23-2013 04:39 PM
Diesel from Gas Station arf145 Gear & Maintenance 15 09-14-2008 01:20 AM
Diesel & Gas Engines? oceanmaui Gear & Maintenance 5 10-24-2004 07:40 PM
gas vs diesel reid5009 Living Aboard 1 02-07-2003 12:43 PM
Diesel or Gas? acmecoyote Gear & Maintenance 3 10-25-2002 06:13 PM
