Yanmar raw water cooling problem - Page 2 - SailNet Community
post #11 of 19 Old 06-08-2009 Thread Starter
Not a lot of scoring. Some faint circular on the inside. Very little on the outer part. While definitely not a highly polished surface, but to my eye looked smooth enough for the gasket to work well.
Is it possible for pump to lose a prime from a leak later in the cooling system. I ask since when I changed the engine zinc the bolt that the zinc screws into was completely frozen. It is mounted into a small cover held on with 4 bolts. All of which moved easily. I was somewhat surprised that there was no gasket on that piece. It doesn't seem to leak, but could let air in I suppose.
noreault is offline
post #12 of 19 Old 06-08-2009
My cover was scored (circular, from the impeller wearing it) enough that you could see it easily, and catch it with a fingernail - maybe 1/32" - 1/16" or so.
Yours sound OK. I am not a mechanic, so maybe someome else can chime in. I think that if your raw water pump and impeller are in good shape, you shoudl not have water or air bypass it. I don't think any air leaks are good. However, air is always in the exhaust elbow, yet doesn't make it's way back through the heat exchanger, and then water pump. Your possible leak is quite far down the line, so it may not be an issue. I do think any leaks / loose clamps near the pump would facilitate the loss of prime.
Let us know how you make out.
Northeaster is offline
post #13 of 19 Old 06-17-2009
old guy :)
rikhall's Avatar
No strainer on intake
Just my personal opinion.
I don't like a strainer on the outside of the boat covering the raw water intake. I prefer a Groco raw water strainer inside. With no covering strainer I can (worst case scenario) remove the hose and shove a close hanger wire down to clear it. We have the raw water strainer inside and we can see if there is sea weed or whatever in it.
Just my personal preference.
Irwin Citation 34
Mystery
rikhall is offline
post #14 of 19 Old 06-17-2009 Thread Starter
Well thanks to all. Everything seems to be in good shape (knocking on wood as I say that). At least no lost of prime since the repair. My plan is to get a raw water strainer on the inside.
noreault is offline
post #15 of 19 Old 06-21-2009
Excellent posts-very, very helpful
blueoctober is offline
post #16 of 19 Old 06-25-2009
I completely agree. Exterior strainers cause many more problems than they solve.
SteveInMD is offline
post #17 of 19 Old 06-25-2009
Cal 9.2 SilverSwan
roline's Avatar
Speed seal does offer an alternative if your willing to pay the price. I like the idea of the Oring seal instead of sealants and gaskets. Paper gasket thickness should be around 0.003" thick possible glycerin treated paper for this application. We used it for rebuilding oil pumps to prevent excessive end play gaps to produce pressure loss.
Cal 9.2 #19 SilverSwan
roline is offline
post #18 of 19 Old 07-05-2013
Re: Yanmar raw water cooling problem
A bit late to joint Q&A for this problem but I have a 1GM10 and have started with over heating after a new thermostat was fitted by the yard.
I have looked at the impeller housing and semi cleaned the gunk off a very thick gasket ( could this be the reason why it was over heating, not enough build up water preassure ? )and fitted a new yanmar gasket paper. Very thin. Problem was it wouldn't seal, so I applied a layer of gasket as an emergency as I was on a swinging mooring which wasn't safe. It worked for now but it hasn't run enough to get really hot and be checked.
I will have a go and clean everything up again and do checks.
My part to the questions. Is. At what point in time after starting engine. Did the water alarm sound off.
The Dysfunctional Sailor is offline
post #19 of 19 Old 04-15-2014
I had a similar problem with my 1982 Yanmar 3GMD but the cause was not the waterpump. The exhaust manifold was completely filled with black rusty slime - see photo. When I cleaned the inside mechanically (screwdriver, chisel, grinder etc) I discovered that the cover was pretty much rusted through - only the rust and slime had kept the water in - I'm glad the blockage happened when I was at the dock.. I am trying to get a new manifold from Yanmar - it's only available in Japan...
That's What Was Inside The Blocked Water Passage Photo by utopf | Photobucket
Hole In Cover Of Manifold Photo by utopf | Photobucket
uaglt is offline
Yanmar 2GM 20(F): Raw or Fresh Water Cooled version. How can I tell? captxtina Gear & Maintenance 8 06-04-2013 10:02 PM
Raw Water Cooling - No Water Coming Out montenido Gear & Maintenance 20 01-21-2009 04:16 PM
MD6A cooling water circuit.. groundhog Gear & Maintenance 0 09-11-2008 05:37 PM
Flushing/testing/preping an old water system on a new old boat tenuki Gear & Maintenance 8 04-19-2007 10:33 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
