Universal 25 question - SailNet Community
post #1 of 4 Old 06-19-2009 Thread Starter
Cuttysark Clark
Angry Universal 25 question
What is that white cylindrical shaped thing hanging over my transmission. I have an 83 catalina 30 and a small oil hose dropped off that unit and oil flowed all over my engine compartment. What is it and why is it resting on my transmission.
Joeclark57 is offline
post #2 of 4 Old 06-19-2009
Typically the FWC heat exchanger sits behind the block over the gearbox.. perhaps you have an oil cooler too??? If so there will be water hoses going to it as well.
Faster is offline
post #3 of 4 Old 06-20-2009 Thread Starter
Cuttysark Clark
Faster, Thank you for your reply. Yes it does have water hoses attached to it and one end says Zinks with a wrench fitting. Should I open that and see if it needs zink replacements?
post #4 of 4 Old 06-20-2009
The fact that it holds a zinc points to this being your coolant heat exchanger and, yes, the pencil zinc could well need replacement. The bigger question is why oil leaked out if this unit (if in fact that's where it came from)
Faster is offline
Universal M25XP / Kubota D950 question kaptaindave Gear & Maintenance 8 12-02-2009 12:39 PM
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 07:25 AM
Motor: DIY or Pay up; that is the question canoeman256 General Discussion (sailing related) 11 10-11-2008 05:16 PM
Universal M-25 engine Gary1 Gear & Maintenance 11 07-15-2008 09:22 AM
Universal M21, long story and fuel line question BarryL Gear & Maintenance 16 05-12-2008 03:37 PM
