Where are the Perkins 4-108 Zincs?? - SailNet Community
post #1 of 6 Old 07-13-2009 Thread Starter
I'm new to the boat - 1982 Morgan 383. The Perkins has a side mounted raw water heat exchanger (without an oil or Hurth transmission cooler - so far I can tell). This configuration is not shown in shop manual.
I have read that some engines have no zincs. Can this be right?
Thanks, John
TSPMorgan383 is offline
post #2 of 6 Old 07-13-2009
moderate?
camaraderie's Avatar
From another forum:
"The 4.108 and all other Perkins marine engines did not have zinc pencils fitted as standard. Presumably they have never been used for exactly the reason described by David; they can break up and cause raw water flow problems. If the engine is properly bonded to the boat's main anode, zincs are not required. You will only find zincs on a 4.108 if the marinisation is non-standard or it has been modified to incorporate them."
camaraderie is offline
post #3 of 6 Old 07-13-2009
Seņor Member
PorFin's Avatar
John,
Sounds like your 4.108 is the same as mine. The unit is a combo header tank and h/x, mounted on the port side of the engine right? If so, it's likely a Bowman h/x (model PE 180).
According to the Bowman folks, their units are not equipped with sacrificial anodes. Don't mistake the drain plug at the aft end of the unit for the anode -- if you do, you'll have a bilge full of antifreeze (don't ask me how I know...)
I'll try to shoot you an engineering diagram of the h/x.
Por Fin
PorFin is offline
post #4 of 6 Old 07-13-2009
My 4-107 has the same setup. I spent some time looking for zincs, no dice. When I cleaned the sea strainer I found some little tablets in it, like zinc tums. I threw a zinc pencil in there.
WanderingStar is offline
post #5 of 6 Old 07-14-2009 Thread Starter
Originally Posted by PorFin View Post
John,
Por Fin
Thanks Por Fin. You have my HX described correctly right down to the "glycol to the bilge" plug.
post #6 of 6 Old 07-14-2009 Thread Starter
Excellent suggestion! Thanks.
Safe Perkins 108 Temp & Pressure bsfree Gear & Maintenance 6 10-02-2007 10:59 PM
Perkins 108 flywheel count bsfree Gear & Maintenance 2 08-26-2007 02:40 PM
Perkins Head Gasket & Hello to All islandzephyr Gear & Maintenance 3 05-21-2007 11:38 AM
Perkins 4-107 Zincs Alden68 Gear & Maintenance 0 05-19-2007 07:40 PM
Engine Zincs jr438234606 Gear & Maintenance 5 05-04-2007 09:22 PM
