Yanmar couldn't get it up - SailNet Community
post #1 of 3 Old 07-19-2009 Thread Starter
Irrationally Exuberant
The oil pressure that is, and it's never happened before, I swear!
OK, really, it never has happened before. My 22 yr old Yanmar 2GM20F always starts right up--like less than a second. Little or no smoke, runs strong, the oil pressure alarm goes off after a couple seconds of running. But the other day, after starting the engine to bring the boat back in, the oil pressure alarm stayed on. Cut the engine, waited a bit and verified that the oil level was good. Restarted, then reved it up to 1000 and the alarm went off. It then stayed off at idle, through running for a half hour, and then idling some more.
I don't believe the engine has a huge # of hours on it, but don't know this for sure. Don't have an oil pressure gauge. I use the recommended 30 wt diesel oil. Could the sender for the oil pressure alarm be going bad?
Thanks.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #2 of 3 Old 07-19-2009
yes the sender can go bad, but for safety i would not run for now.
if you take the sender out a good auto machine shop should be able to test it. heck you might be able to get a new one that works at napa auto part, just make sure the pressure setting is the same
scottyt is offline
post #3 of 3 Old 07-19-2009
Those pressure senders DO go bad. Or, the pressure adjustment in your oil pump (often a spring) could be bad. There's usually a resistance check you can perform to test the sender but if a new one is $15-20 and the old one is already ten years old, it might be simpler to just replace it.
While it is out, you stick a mechanical oil pressure gauge into the port (or whereever an oil pressure gauge can be used on your engine) and double-check that you really have oil pressure. Better to be conservative when it comes to oil problems. This could also be the tie to consider plumbing in a real 9electric) oil pressure sender and gauge and "just do it".
hellosailor is offline
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Beneteau vs. Yanmar – Green vs. Red Cooling Fluid Swesail Gear & Maintenance 37 04-14-2009 12:32 PM
Yanmar Problem Solved... Warren M. Gear & Maintenance 1 09-01-2008 09:39 PM
Yanmar Engine Mount Specifications HenryTully Gear & Maintenance 4 06-27-2008 10:20 AM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
