Yanmar Oil Pressure - SailNet Community
post #1 of 6 Old 07-28-2009 Thread Starter
Doug K
Yanmar Oil Pressure
I have a 3gm 22 hp w/ 4500 hrs on her. The oil pressure gauge normally sits at 40. At 2200 rpm's the gauge is dropping to about 25-30. Anyone know what's the normal pressure range?
Searunner37 is offline
post #2 of 6 Old 07-28-2009
timebandit's Avatar
For your engine--40
You might want to check for fuel in the oil that might thin the oil and reduce the oil pressure.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #3 of 6 Old 07-28-2009 Thread Starter
Doug K
Yanmar Oil Pressure
Thanks for that advice on fuel in the oil. We just ran the engine pretty hard on a ten day cruise around the Delmarva Peninsula with out much wind. I am about to change out the oil with Rotella 15w-40w. We had been using Castrol 15w-40w. The engine is starting to get into the 190 degree range when I run the rpm's above 2200 leading me to think heat exchanger needs to be serviced. I'll change out the impeller as well. I was thinking the high temps may have something to do with a drop in oil pressure.
post #4 of 6 Old 07-28-2009
If you do have diesel thinning the oil the diaphragm of the fuel pump is probably ruptured, if this is so you should see a rise in the oil level as well.
On the rise in temperature, if you have a heat exchanger on a 22HP 3GM you have a 3GMF. I found I had the same problem with my 3GMF and it turned out to be the small elbow on the water injection into the exhaust elbow. These engines also suffer from the exhaust elbow itself becoming blocked with carbon and corrosion. The heat exchanger is of course another point to check as you already noted.
r.furborough is offline
post #5 of 6 Old 07-29-2009 Thread Starter
Doug K
I think you may have nailed it. I do have a 3GMF. The last time I looked over the heat exchanger I ran some welding rods thru it. It looked pretty clean. That was about 175 hours back. I'll check out that exhaust elbow. I may have overfilled the oil level bit when I was topping up after 26 hours of motoring. Do you think this could have affected the fuel pump diaphragm? I found it curious that when I went to top up after another 10 hours engine time that the oil level was just above full.
post #6 of 6 Old 07-29-2009
Sent you a PM....
Yanmar Oil Pressure Light/Alarm Out? Please help! gwp Gear & Maintenance 1 05-19-2008 11:32 PM
Yanmar oil pressure brak Gear & Maintenance 4 05-04-2008 09:40 PM
Oil Pressure Mystery Solved bsfree Gear & Maintenance 5 12-21-2007 07:23 PM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
Oil Pressure Problems Tom Wood Gear and Maintenance Articles 0 05-16-2002 08:00 PM
