exhaust woes - Page 2 - SailNet Community
post #11 of 11 Old 08-05-2009
Hull Number 33
OldColumbia's Avatar
Dear Jhack,
You're absolutely right, it's "raw" water from the heat exchanger cicuit. I comes from the pump driven by the V belt supplied by the seacock typically by a 3/4' or 1" hose that enters the exhaust on the " down" side of either your homemade or manufactured exhaust riser or elbow.
Some water lock mufflers are metal, some are plastic some have drains to winterize or drain the exhaust system but most are about the same size for small diesel auxiallary engines less than 40HP. the key issue is whether the remaining water in the exhaust can be drained away from the engine when it isn't running.
You can buy manufactured exhaust elbows and risers from Original Equipment manufacturers or aftermarket manufacturers since almost every inboard powered boat needs one except for "drystack" exhausts used on fishing boats and trawlers.
It really depends on whether your engine is above or below the waterline to determine if you need a riser or not. Westerbeke has great Adobe manuals on line foor the 25XP to locate parts numbers. The elbows for the 3 cylinder M30 might work as well.
OldColumbia is offline
Wallas Stove Woes (And Remedies?) badge Gear & Maintenance 11 05-06-2011 05:40 AM
Any Gearhead's? Capnblu Sailboat Design and Construction 40 11-23-2008 06:58 PM
1967 Irwin 37 cc with exhaust problem Irwin37mkIV Irwin 5 08-02-2007 07:03 PM
Diesel Exhaust Systems Sue & Larry Gear and Maintenance Articles 0 11-07-2001 07:00 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
