Isuzu diesels - SailNet Community
post #1 of 6 Old 08-04-2009 Thread Starter
Isuzu diesels
I need to replace my auxiliary diesel and marinised Isuzu diesels seem to have a good name all over. Do members have an opinion on this? And if so, my choice would be either the 4LC1 4 cylinder 38 hp or the 3CD1 3 cylinder 35.5 hp. Both ratings at 3000 rpm. 3 larger cylinders or 4 smaller cylinders? More complexity or more vibration?
Thanks. Bill
clarity36 is offline
post #2 of 6 Old 08-04-2009
Don Radcliffe
There are Isuzu powered trucks (and Isuzu parts) ALL over the world. However, I did see a boat in Cyprus with an Isuzu where the timing belt had broken and resulted in serious damage. I would avoid motors with timing belts.
donradclife is offline
post #3 of 6 Old 08-04-2009
Valiente's Avatar
Kubota is also a good option for avoiding the "marine diesel" spare parts scam industry.
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
post #4 of 6 Old 08-04-2009
JamesSkok's Avatar
Isuzu diesels
May I suggest that you consider the BETA MARINE diesels that use the Kubota blocks. They are reliable and the easiest to maintain, e.g. the integrated oil change sump pump. Everything on these engines is accessible. I have the Beta 14, 2 cylinders with 13.5 bhp weighing in at only 94 Kg in my Ericson 27. The engine is designed as a drop-in replacement for the Atomic 4. I am no motor-head, but it is a straightforward engineering application. They have a family of greater horsepower engines and gensets. It's worth a visit. The web address is Beta Marine US Ltd. Distributors for Kubota based marine.
JamesSkok is offline
post #5 of 6 Old 08-04-2009
night0wl's Avatar
Can you go over the costs of your repower?
S/V Jendai
Beneteau 343
night0wl is offline
post #6 of 6 Old 08-04-2009 Thread Starter
Clarity repower
Hi Night Owl. Zenith Engineering marinise Isuzu diesels here in Brisbane, Oz, and advise that the fine for a 35 hp is $15k ozdolls and the 53hp is $16k, both with a full VDO panel and wiring harness. A 40hp marinised Kubota from either Nanni or Wichard Marine here in Oz runs to around $14-$15k
A base Kubota industrial 46hp engine here is $6.5k; ZF box around $2.5k; Orca marinising kit around $2.5k and Murphy instrumentation $900 = about $12.5k if I do the work myself.
It's not a lot compared to the overall value of the ship, but it involves a bit of saving for the skipper. Cheers!
Vetus Diesels? TSteele65 Gear & Maintenance 9 09-13-2007 03:29 PM
Vetus Diesels?? jemsea Boat Review and Purchase Forum 2 06-27-2005 05:03 AM
begining book on diesels anneminix Gear & Maintenance 1 04-10-2003 03:28 AM
Question about marine diesels bdkorth Learning to Sail 9 07-03-2002 10:52 AM
diesels anneminix Gear & Maintenance 1 10-26-2001 07:51 AM
