Ooops. Water Contamination in Diesel Tank - Page 2 - SailNet Community
post #11 of 14 Old 08-24-2009
TQA
Bombay Explorer 44
TQA's Avatar
isopropanol not familiar with this BUT is there any chance it could attack anything in the system like hoses - seals - O rings.
TQA is online now
post #12 of 14 Old 08-24-2009
midlife crisis member
AllThumbs's Avatar
I would put the (rubbing) alcohol in, let it mix with whatever water may be in there, and then pump it out.
I sail.
AllThumbs is offline
post #13 of 14 Old 08-24-2009
Isopropanol is aka isopropyl alcohol. I'm sure it is not identical to ethanol or methanol but AFAIK it is the same in terms of effects in fuel systems or other places. A short exposure wouldn't harm anything in the typical fuel tank or system, although prolonged or concentrated use dries out rubber and other materials.
As a tank cleaner? Arguably the safest material you can use, unless you want to just heat the tahk until all the water evaporates. With the alcohol, it will evaporate out much sooner.
hellosailor is offline
post #14 of 14 Old 08-28-2009
This is simple, as hellosailor said, pour in a gal of alchol, pump it out fill with clean diesel and be on your way, the filter will remove what little water is left. The clear bowl racors are certainly better to see what you have in them
motion300 is offline
Restarting Fresh water davidpm Gear & Maintenance 0 04-23-2009 08:50 PM
Diesel exhaust- water? MBesant Gear & Maintenance 26 07-18-2007 05:19 AM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
