Yanmar 2QM15 fuel consumption? - SailNet Community
post #1 of 10 Old 09-02-2009 Thread Starter
Hello: does anyone know what the fuel consumption is for a 2QM15? My new old sailboat doesn't have a fuel sensor; I could figure it out over time measuring engine hours against each top up, but maybe someone's already got the number. I cruise at about 2100 RPM.
The previous owner says he got about 70 hours of service from one tank. Going from 35 US gal tank to litres per hour I estimate 1.9L/hour. Does this sound right?
I welcome any thoughts-thanks.
30Irwin is offline
post #2 of 10 Old 09-02-2009
my 1 gm is slightly over a pint an hour by the specs, but i think it runs closer to 2 pints. maybe due to age or the fact that right now the head is being rebuilt. i would guess its close to twice the fuel use as my 1gm, so in reality its probably closer to 1/2 gallon an hour.
if you really want to know, for real rig up a one gallon gas ( i know diesel fuel ) can to the fuel input and return and run it until you use a 1/2 gallon
scottyt is offline
post #3 of 10 Old 09-02-2009
catamount's Avatar
Yes, that's pretty close. I use the figure of around 1/2 gallon (US) per hour at my moderate cruising speed (no tachometer). Yanmar specifications (you do have the factory Service Manual, right?), though, actually suggest a little higher fuel consumption, around 0.7 gallons (us) per hour at full power.
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
catamount is offline
post #4 of 10 Old 09-02-2009 Thread Starter
Sounds like I'm in the right ballpark--I really had no idea what the approximation is: thanks a lot for the validation.
30Irwin is offline
post #5 of 10 Old 09-03-2009
2QM Fuel consumption
I had one of these engines in my previous boat. You can burn 1/2 gallon per hour, but have to really run it hard to do that. But if you use that figure, you should be safe.
Dream like you will live forever. Live like you will die tomorrow. ( James Dean )
flatracker is offline
post #6 of 10 Old 09-04-2009
Cal 9.2 SilverSwan
roline's Avatar
Hull Speed vs RPM
The rule of thumb that I've used is that you have 18 hp-hrs in a gallon of diesel. For a 2GM20 turning 2800 rpm with a 14dx12p prop cruising @ 6.3 knots, I burn just over a gallon in 2 hrs. (about 9hp)
If I run at 3200 rpm, I burn about an additional 1/2 gallon without much improvement in hull speed. (about 14hp).
See attached graph....
Cal 9.2 #19 SilverSwan
roline is offline
post #7 of 10 Old 09-04-2009
catamount's Avatar
The 2QM15 is rated at 14 horsepower, so 14/18 = 0.777 gallons per hour, which is pretty close to Yanmar's spec for the engine. Just some confirmation of your rule of thumb....
post #8 of 10 Old 09-04-2009
DrB
+1 on the responses
My 3GM30F Yannie, burns on average about 0.5 to 0.7 gallons an hour depending on RPM.
I think a safe number is 0.7 gal an hour for your purpose.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #9 of 10 Old 09-04-2009 Thread Starter
Excellent feedback from all; thanks again.
30Irwin is offline
post #10 of 10 Old 09-05-2009
Selkirk's Avatar
Rule:
Diesels burn about 1 gal/hour per 20 HP developed.
Gasoline burners use 1 gal/hour per 10 HP developed.
When you come to a "Y" in the road, take it....Yogi Berra
Selkirk is offline
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 41 09-24-2016 12:03 AM
Yanmar 1GM Diesel fuel consumption H216Sailor Gear & Maintenance 15 04-03-2008 09:17 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 08:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 08:00 PM
Yanmar 2QM15 Bleeding Fuel System - HELP shipley Gear & Maintenance 5 03-11-2002 08:21 PM
