Which electric fuel pump to add in series on a M5411 - Page 2 - SailNet Community
post #11 of 14 Old 09-15-2009
One of None
deniseO30's Avatar
uh.. I have a squeeze bulb on mine just like the one on a outboard. works great after filter changes. Never had a problem with it otherwise.
My last project!
deniseO30 is offline
post #12 of 14 Old 09-16-2009
I just installed this with a new Racor 500:
http://wem.walbro.com/distributors/FR/FRB-13.htm
Configuration is tank -> Racor filter -> Walbro -> engine (yanmar 2gm20f).
I turned the pump on and the Racor filled up in under 5 seconds.
I ran the pump for an hour (installed fuel polishing valves and T as well) and got about 7 oz of water out.
Switched it over to the engine, changed the primary filter and bled the line in a few seconds with just a quick flick of power to the pump.
The engine draws fuel just fine with the pump off (it is designed for flow thru).
Lots of lurking here led to this system which is simple yet very functional. Thanks to everyone who provided all the little bits and pieces of info.
SVCetacea is offline
post #13 of 14 Old 10-15-2009 Thread Starter
Originally Posted by coral47 View Post
Hello All,
I am not technically expert, but just know that not possible to place both pumps in series, but we can place them in parallel, so that we can use that alternately.
Thanks!
crofrog is offline
post #14 of 14 Old 10-16-2009
timebandit's Avatar
I see you have protected the system by filtering the fuel before the pumps but--
Inlet Filter Screen: 70 micron--From the pump specs
Might be something to remember is you run into fuel starvation problems.
The other thing to remember is that with the eletric pump pushing through the manual on the the engine there is the danger that if the diphram on the manual ruptures the electric will fill the engine crankcase with fuel.
Only for this reason would I tee and go around the engine fuel pump.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
