New Yanmar, hard to start, or just cold natured? - Page 4 - SailNet Community
post #31 of 33 Old 09-29-2009
With all due respect for my fellow members here...
Looking for a leak...if you have a leak before the lift pump it will be hard to find since it will always be under suction. You just have to go connection by connection and do your best. You could temporarily change our the fuel line leading into the lift pump with clear tubing provided you can find some with thick enough walls so it doesn't collapse. The clear line would show you if you have an air leak before the lift pump. You should see no bubbles with the motor running.
If the leak is between the lift pump and the high pressure pump you should be able to see wetness or dripping fuel.
If the leak were after the high pressure pump you would be running on less than all cylinders, and running rough so I don't think that's the case.
With the hours on the motor you have it's very unlikely to be a bad injector. You can remove them and send them off to be rebuilt, but I think you are barking up the wrong tree.
If you injector pump is so bad that it's leaking back I doubt your motor would run at all. Normally injector pumps do not leak back what so ever. It's also very unlikely the problem at the low hours you have.
You should be able to crack the bleed screw a little on top the secondary filter with the motor running and fuel should squirt out. If not you may have a weak lift pump. Again, this is unlikely since it's a new motor.
If you don't have the Yanmar Parts Manual and Service Manual you should buy them.
You might find taking a class useful. I've worked around diesels for many years, but I learned a lot by taking a level 1 and 2 class on marine diesels. I learned a ton and have put what I learned to good use on my boat.
SteveInMD is offline
post #32 of 33 Old 10-04-2009 Thread Starter
Finally. I want to thank everyone for your help. The first thing I did when I got to the boat was bleed the fuel system. Lot of air! So I went over every fitting from the fuel tank to the engine. One or two seemed lose to me. Pulled the filters checked the gaskets. Bleed the system again and low and behold. Finally she starts like a diesel should. Next morning, touch the key, no glow plugs, less than a second fires right up. YYAAHHOO!!! Let set threw the day same thing. Next morning Same thing!!!!
Thank You All for all your help!!!!!!!
Dozer
Dockdozer is offline
post #33 of 33 Old 11-24-2009
Sailor
I had the same problem at first. I was doing what the dealer showed me: Glow plugs, rev it up a little, then start. Yet it always stopped after a few seconds...
Then I learned that in warm weather YOU SHOULDN'T HAVE TO DO ANYTHING AT ALL. Now I just turn the key and it starts. Every time!
CanDrac is offline
Hard Warm Starting Yanmar ysm8 mhfowle Gear & Maintenance 7 12-20-2006 01:45 PM
Cold Weather Engine Start bmelchionda Gear & Maintenance 18 11-05-2006 09:55 PM
Can't start My Yanmar bun243 Gear & Maintenance 8 06-04-2006 01:22 AM
Cold Weather Clothing Bob Merrick Learning to Sail Articles 0 02-24-2004 07:00 PM
Recovering from Bad Starts Dean Brenner Racing Articles 0 05-29-2002 08:00 PM
