Question : Install New Engine vs Rebuild - Page 2 - SailNet Community
post #11 of 18 Old 09-20-2009 Thread Starter
Waiting For Spring
krozet's Avatar
I have a line on a re manufactured Yanmar 3GM30F. The info I have received is that the shop has replaced everything except the block. The price is $3900 and comes with a two year inclusive warranty.
I can't find a new 3GM30F or 2GM20F as these have been replaced in the Yanmar catalog with the 3YM20 and 3YM30 and I can't find a price for either of these engines.
For new I have found a Yanmar 3JH3-E that has 40HP but the weight is 100Kg more than the current engine. A couple Westerbeke 30B three's that weigh less than the current engine but output 27HP. A Volvo Penta D1-30 with 29HP that weighs just a little more.
I can't seem to track down an active owners group for my boat so comparing setups isn't going to be possible.
krozet is offline
post #12 of 18 Old 09-20-2009 Thread Starter
Waiting For Spring
krozet's Avatar
Originally Posted by DwayneSpeer View Post
If the old engine is raw water cooled don't even think about a rebuild. The old engine, even if rebuilt is just waiting to fail due to something inside corroding thru.
I don't know about all the manufacturers but when I repowered with a new Beta they made engine mounts that fit onto my old engine bed. I just had some adapter plates made so that the new mount bolts and the old bolt holes worked. No big deal and definitely no rebuilding the engine mounts!
Also, I did all of the installation work on my project and I'm just a back yard mechanic. The two things that were a bit unusual were that the new engine turned opposite of the old and the throttle hookup was also backwards. I now run my transmission in reverse for forward, no big deal for a Volvo Sail Drive, and hooked the throttle up backwards also. Both readily achievable.
The bottom line. Don't give up on a new engine of a different make until you have looked into it very carefully and are sure it just won't work.
GOOD LUCK!
Current engine is a fresh water cooled engine with a heat exchanger.
krozet is offline
post #13 of 18 Old 09-24-2009
Before deciding on a significantly larger engine I recommend checking out Dave Gerr's "Propeller Handbook" from the library. Overpowering can be problematic for the diesel if that means the engine will not normally be run at 80-90% full load.
Waltthesalt is offline
post #14 of 18 Old 09-24-2009 Thread Starter
Waiting For Spring
krozet's Avatar
I'll have to show my ignorance of Diesel Engines here but wouldn't it prolong the life of an engine if it didn't have to run at 80% to 90% load on a consistent basis? I thought I would be ahead of the game If I had a 30HP engine on a 12,000lb boat with the proper propeller.
But that's why I'm here, to learn.
Thanks for any feedback;
Robert
1971 Contest 33 Hull Number 24
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
Mark Twain
krozet is offline
post #15 of 18 Old 09-24-2009
So - Robert... have you done the deal on the boat yet?
Faster is offline
post #16 of 18 Old 09-24-2009 Thread Starter
Waiting For Spring
krozet's Avatar
Deposit paid last week, final payment tomorrow.
The current owner scanned and emailed me the Florida title of the boat, and since that title is in the name of the previous owner he sent me the sales contract from the previous owner to himself. The current owner never transferred the title as he lives overseas and didn't know if he was going to sell the boat or sail it home. He scanned and emailed me a sales contract from himself to me as well as an example letter for me to use too get the title canceled in Florida so I could start the process of getting the boat registered in Canada. I have emailed the Florida Department of Highway Safety and Motor Vehicles 2 days ago asking them what I need to do in order too get a letter of cancellation for the boat title from their system but have yet to hear back from them. If I don't hear from them today I will have to call them.
I almost started a thread about the whole process but thought I had started enough threads in the last week and didn't want to irritate anyone.
Guess I will be the proud owner of an expensive hole in the water in the next couple days.
Robert
Mark Twain
krozet is offline
post #17 of 18 Old 09-24-2009
Repower
Especially for auxiliaries, diesels suffer most from not being run for sustained periods at power. Having said that different diesels have service ratings. Generally the manufacturer can advise you on this and given the specs for your boat they can make a recommendation of the power best suited for you. Where the propeller comes in is matching its' performance curve with your engine's Shaft Horse Power curve (from .94 to .96 of BHP or Brake Horse Power which is what's normally in the specs.) performance, for sailboats the goal is to get the curves to match at normally 90% power. The prop's diameter is normally limited by the hull or skeg clearance from the blade tip. You need at least 15% of the blade's diameter for clearance. The next issue is blade pitch. Too much pitch and your engine won't get up to speed, too little and it will overspeed at full throttle. After pitch comes is blade area, too little area and the prop will gravitate at full power. So if your diameter is limited you may have to go from a two bladed prop to a three bladed prop to get sufficient blade area. Propeller manufacturers will calculate the right prop given you boat and engine specifications. Michigan Wheel is a good one for this.
A note: Some manufacturers show both BHP and ISO 8665 power curves. the ISO deals with controlled testing conditions which I don't know much about. Prop manufactures seem ot with using the BHP number for thier calculations.
Again David Gerr's book has all this info
post #18 of 18 Old 09-24-2009
Congratulations.... hope the rest of the process goes smoothly for you.. the engine swap may be easier than the paperwork! Best of luck.
Faster is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
