Old Isuzu DH100 died, need a replacement - SailNet Community
post #1 of 5 Old 09-19-2009 Thread Starter
dsbentley's Avatar
Send a message via AIM to dsbentley Send a message via MSN to dsbentley Send a message via Yahoo to dsbentley
My 28 Year Old Isuzu DH100 180HP diesel gave up the ghost and is not worth rebuilding so I am looking at option. We live in the Caribbean to looking to reliability with parts! I have been told top look at Yanmar, John Deere and Perkins. Any thoughts from you experts before I dive into this project head first? I am hoping I can use my old transmission as this is still in good shape. I know I will likely have to modify engine mounts and other accesories.
dsbentley is offline
post #2 of 5 Old 09-20-2009
Any Kubota based system will work fine. Lots of spare parts too at farm tractor dealerships believe it or not.
Same for yanmar, which is the largest builder of tractor engines.
all basic engine parts are easily available if you know the block designation and the number. quick cross ref to farm and construction engines.
DO NOT buy a marine only engine style. Then they have you.
Deere is a good choice. Perkins diesels are used all over as well....Massy Ferguson uses Perkins diesels.
big savings if you get a block that is identical to a farm / construction equipment spec. Marine dealers overcharge.
jefframage is offline
post #3 of 5 Old 09-21-2009 Thread Starter
dsbentley's Avatar
My question is will my old transmission mount to the new engine? Are most marine transmission bell housings the same? Should I have the transmission rebuilt? It works just fine now. I have been told I should just change out the clutch in the transmission.
post #4 of 5 Old 09-21-2009
Courtney the Dancer
jrd22's Avatar
You will have to check the schematics of the new engines you are considering to see if everything (bolt pattern, input shaft splines, etc.) are exactly the same. You would have to find an engine that runs at the same rpm as the old one too. Why would you want to keep a 28 year old tranny after going to all the work to put a brand new engine in? Most new marine engines come with a transmission matched to the engine. I would look at Cummins also.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #5 of 5 Old 09-22-2009
transmission connection to new engine
It is likely there is a bell housing manufactured to do just that, as long as your transmission is a "standard" type. Most have similiar bolt patterns.
Splines tend to be standard, but again, use "quotes" lol. You know the saying..customer service isn't...well ...... standards arent. lol.
best thing to do is to find several motors that you'd find acceptable, and then find one of them that will bolt up.
If you can swing the dime for a new tranny and a new "standard" build, then you'd probably be better off. Engines that are 28 years apart in technology, might not have the same power curve, and that might soon tear up an older, unmatched tranny.
keep us informed, I"d like to know how this comes out, and how satisfied you are with the new engine, and your engine choice.
Hot Water Heater Replacement sailthechesapke Gear & Maintenance 2 04-09-2013 11:46 AM
Looking for an instrument cover replacement Northbeach Gear & Maintenance 5 01-13-2007 01:30 AM
Motor mount replacement? bread316 Gear & Maintenance 4 11-07-2006 12:17 AM
Coroner: Man died from natural causes during sailboat race - WHNS NewsReader News Feeds 0 10-07-2006 02:15 PM
Coroner: Maine Man Died From Natural Causes During Sailboat Race - WMTW NewsReader News Feeds 0 10-05-2006 11:15 AM
