Type of oil used for diesel engine - SailNet Community
post #1 of 17 Old 09-21-2009 Thread Starter
The owners manual for my Yanmar 2ym15 engine says to use 10w30 oil. Can I use standard automotive oil, or do I need a special oil for diesel/marine applications?
voice3 is offline
post #2 of 17 Old 09-21-2009
Maine Sail's Avatar
Use a C rated oil not an S rated. C rated oils are for diesel S are for gas.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 17 Old 09-21-2009 Thread Starter
Thanks for the info. Where can I get C rated oil, and what brand do you recommend?
Matt
voice3 is offline
post #4 of 17 Old 09-21-2009
Maine Sail's Avatar
Wal*Mart sells both DElO 400 and Rotella T though mostly in 15W-40 which is the oil most used in diesels..
______
post #5 of 17 Old 09-21-2009
MS - I'd be interested in your thoughts on the Synthetic oils and boat diesels.
Faster is offline
post #6 of 17 Old 09-21-2009
Courtney the Dancer
jrd22's Avatar
Faster- I hope MS or someone else gives some info. on the synthetics also. My experience with diesels is that unless you start using the syn's from when the engine is new it can develop a lot of leaks past crank seals etc. We put synthetic in a John Deere that had a lot of hours (several thousand) and it leaked out everywhere. We put Rotella back in and no leaks. We had another engine do the same, but it was a gas engine.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #7 of 17 Old 09-21-2009
Thanks John.. I'd heard something along that line before, and have had others tell me that the synths are great and worth the extra cost. However I've been reluctant to make the switch without more info..
Faster is offline
post #8 of 17 Old 09-21-2009
Splashed
JomsViking's Avatar
"Traditional" boat diesels that are naturally aspirated, do not like synthetic oils - Quite often they are designed to use grade CD which is so old that it can be hard to find.
If you use "better" oils than CC/CD, bore glazing and oil bruning may be the result.
Watch great footage about the story of one manís slow odyssey around the UK:
JomsViking is offline
post #9 of 17 Old 09-21-2009
Look on the back of the container. There'll be a circle with the grade in the middle and the service designation around the top:
Anything with a Cx listed is rated for diesel engines. Each time they revise the service designation they increment "x". CD was introduced in 1955, and has been superseded by CE, CF, CG, CH, CI and now CJ. Each oil in the sequence is an approved replacement for those before it.
If you can't find 10W30 easily with a Cx designation, look for a straight 30 weight. The 10W part means it's a winter rated multigrade oil. Since you're probably not going to be using your boat in freezing temperatures, the cold weather properties of a 10W30 aren't needed.
Tim
Gramp34 is offline
post #10 of 17 Old 09-21-2009 Thread Starter
My Motor is only a couple years old. I'm not sure if synthetic oil was used in the past. Is it too old to switch to synthetic if standard oil was used in the past?
voice3 is offline
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
Safety Check Mark Matthews Learning to Sail Articles 0 01-25-2000 07:00 PM
