Repower a DH100 Isuzu on a 58' Full Keel sailboat - SailNet Community
post #1 of 9 Old 10-02-2009 Thread Starter
dsbentley's Avatar
Send a message via AIM to dsbentley Send a message via MSN to dsbentley Send a message via Yahoo to dsbentley
My father built a Roberts 58 in Seattle Wa and she was launched in 1990. I am having to repower the main engine and really need some quick help and advice on what size engine to replace the old DH100 Isuzu 190HP that my father installed and purchased from MER Equipment in Seattle. I will give you some background information to help you understand what we are dealing with.fficeffice" />>>
The boat was a one off Airex foam core hull and was built to the heaviest standards. We have 25,000 lbs of lead in the keel and hold 900 gallons of water and 900 gallons of fuel. I was told the recommended engine size was 90 120HP but my father always went overboard and installed a 190HP with a Capitol 3 to 1 transmission turning a 2 shaft to a 28 (we think) prop. We estimate the boat to weigh between 65K and 70K so she is heavy. I motor sailed the boat down to the Caribbean 3 years ago. We are only able to get 6 to 7 knots at 1500 RPM with the current engine and when we go higher in RPM the boat makes a grinding sound in the shaft near the back where the shaft exits the hull. I know (to the best of my knowledge) that the shaft is straight and the carrier bearing is good so the noise could be coming from the prop being mis-sized or the pitch of the prop. I am told the boat should do 10 to 11 knots on the hull speed. I have had the reps at Yanmar say I can use a 200HP 4LHA-DTP engine with a 2.8 to 1 transmission to turn the 28 prop. I am concerned that to get the 200HP I will need to run the engine at over 2800PRM and may have the same problem I am having now. I am told I need to start with what prop is designed to be used with this hull and go forward from there. >>
Can you tell me what engine HP and prop size has been used on similar boats and what you would recommend we use now. I really need this answer ASAP as I need to order the new engine by Monday to get it shipped here in time. I will include a picture of the boat out of the water and the prop currently being used. Let me know if there is a number I can call to talk about this.>>
dsbentley is offline
post #2 of 9 Old 10-02-2009
timebandit's Avatar
"We are only able to get 6 to 7 knots at 1500 RPM with the current engine and when we go higher in RPM the boat makes a grinding sound in the shaft near the back where the shaft exits the hull."
Will the motor go over 2400 rpm in gear even with the noise??
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #3 of 9 Old 10-02-2009 Thread Starter
dsbentley's Avatar
Good Question, we never went above 1800 to 2000 RPM and didnt seem to get much more speed. Here is what Bruce Roberts Austraila had to say
"Re the statement 'I am told I need to start with what prop is designed to be used with this hull and go forward from there.' This is not really correct. With the large variance in displacement with home built vessels and the engine the builder can get the best deal on we work out on a individual basis the reduction gear and prop best suited for the vessel as part of ongoing service. Bruce may do the same. The hull speed of the HM 57 is around 10 to 11 kts and it would amaze me if the grinding noise you hear is from the prop."
This does not really help me figure out what size prop I should use.fficeffice" />>>
post #4 of 9 Old 10-03-2009
JimsCAL's Avatar
Rule of thumb is about 2 HP per 1000 lbs displacement, so 150 HP should be enough. The correct prop pitch is critical in being able to actually operate the engine at rated power and RPM. Two much pitch and the engine will bog down and won't reach rated RPM and power. Two little and it reaches max RPM at less than rated torque and therefore less than rated power. I would contact a couple prop manufacturers to see what they recommend for size and see if your current prop is close. Note that the transmission reduction is also a factor as it affects the prop RPM at a given engine speed.
JimsCAL is offline
post #5 of 9 Old 10-03-2009
timebandit's Avatar
So how fast did the boat go in 1990 with the 190 HP engine and current trans and prop?
Going to 200 HP and still only running at 1800 RPM because something behind the engine is making a grinding noise will not get you any more speed.
I guess installing a 400 HP engine might make 200 HP at 1800 RPM but to get 10 kts. you would have to double the pitch of the prop wich would probably need 400 HP at 1800 RPM and to get that you might need at least 800 HP.
Powertrains DON'T make grinding noises.
Rick
Mac 25
Copernicus
Southern California
post #6 of 9 Old 10-03-2016
Re: Repower a DH100 Isuzu on a 58' Full Keel sailboat
do you have torque values
en_teng is offline
post #7 of 9 Old 10-03-2016
Here ya go.............
https://www.vicprop.com/displacement...tion=calculate
gonecrusin is offline
post #8 of 9 Old 10-03-2016
JimsCAL's Avatar
For what? This is your first post here and you are replying to a 7 year old thread.
S/V First Tracks
1985 Cal 33-2
JimsCAL is offline
post #9 of 9 Old 10-07-2016
yeah i know its a 7year old thread, i have dh100 6 cylinder isuzu engine for rebuilt, thats why i need torq values for cylinder head,main bearing, con rod, sorry for my ignorance just a newbie hear ive try searching Re: torq this thread pops
hope you can help.
en_teng is offline
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 17 07-30-2014 09:23 AM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 04:39 PM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Keel Anxiety! Spang Boat Review and Purchase Forum 8 06-19-2006 03:09 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
