-   Diesel (http://www.sailnet.com/forums/diesel/)
-   -   replacing our Universal 25XP (http://www.sailnet.com/forums/diesel/58655-replacing-our-universal-25xp.html)
inshallamiami 10-05-2009 09:05 PM
We are replacing the Universal 25XP on our Morgan 34. We are going back and forth between another Universal: the 25XPB or going with a Yanmar 3ym30. We will be doing the installation ourselves. The Universal is more expensive but we figure it would be a very close replacement and therefore easier to install than the Yanmar, whose mounting dimensions re different.
Anyone have experience replacing their Universal with either another Universal or the Yanmar?
I would appreciate any advice/observations/warnings.
Thanks
Patrick
rdstanley 10-05-2009 10:04 PM
Have you considered the Beta Marine Engines? I've heard good things about them. Just a thought.
inshallamiami 10-05-2009 10:18 PM
Yeah, we've considered Beta, and it's not ruled out. We've done a LOT of research but would like to hear from someone who did their own work.
nccat30 02-07-2010 08:57 AM
I think the universals are just kubotas at least my m25 is.I think the betas are marinized kubotas as well. someone correct me if I'm wrong,but if those things are true then the beta should be very similar. Just a thought
Faster 02-07-2010 09:30 AM
If you were otherwise happy with the Universal, I'd stick with it. Engine parts will be available inexpensively through Kubota, an option not available with Yanmar. If your present engine is FWC, have you considered simply rebuilding it? No installation complications and, again, parts/bearings/gaskets etc from Kubota should make that option quite palatable.
OldColumbia 02-08-2010 04:51 PM
The problem changing engine manufacturers is the different dimensions, shaft length, prop size, and hose placement. etc. Our last repower evolved into relocating the hot water heater, new motor mounts, new shaft ( shorter), cutlass bearing ( the shaft was out anyway), relocating coolant tanks, and replacing control cables because of change in throttle location and transmission shift lever.
Each costing more in parts and labor. I'd keep it simple with a like kind engine.
r.furborough 02-08-2010 07:32 PM
Unfortunately, even sticking to the same engine manufacturer/marinizer can necessitate the same upgrades/updates as the base model of the engine in the used will have changed since the model in the boat. The marinizer of the engine has littlle to no influence on the position of some of the engine controls and services, even Yanmar had changes to which side the heat exchanger and exhaust was on the change from the GM Series to it's replacement, the YM series.
redhead78 02-15-2010 04:59 PM
patrick, where are you located, I am in the process of taking delivery of a beta marine Kubota 35 HP. I am doing repower myself. Check with Kubota dealer I think they have a kubota setup for the universal. I am using SoundMarine Diesel in Conn great dealer support......Red
