Replacing zinc on Yanmar 20M20F - SailNet Community
post #1 of 7 Old 10-10-2009 Thread Starter
Question Replacing zinc on Yanmar 20M20F
I am new to sailing and own a 2001 Hunter 320. I was reviewing the Owners Manual to the Yanmar 2GM20F and it states you should replace the engine zinc every 300 hours. The manual indicates the cooling system is a "Fresh water cooling with heat exchanger".
My question is, where is the zinc located?
Thanks for any help!
BarefootMambo is offline
post #2 of 7 Old 10-10-2009
CrazyRu's Avatar
It would be best to locate service manual for an engine with diagrams, showing parts.
However, most likely you have zinc somewhere on a heat exchanger. Iím not familiar with your engine. Just look at the heat exchanger and locate a bolt which makes no sense. It is something sticking on a side without apparent reason. Unscrew it, most likely there is pencil type zinc screwed to inside of this bolt.
I hope someone with knowledge of the engine will prove me wrong
CrazyRu is offline
post #3 of 7 Old 10-10-2009
ChuckA's Avatar
You can download Yannmar manuals here.
motoren.ath.cx: Yanmar motoren, motors engine | manual download
I just signed a Purchase & Sales agreement on a Pearson 28 with a Yanmar 2GM20F, and was looking for similar info. I haven't done a detailed search, but I found a thread on sailboat owners that says only the raw water cooled version (2GM20) has a zinc.
Engine zincs in Yanmar 2GM20F ? [Archive] - SailboatOwners.com
Best,
ChuckA
sailing a P28-1 Heart of Gold on Narragansett Bay
Twitter: @CoastalCafe_NE
ChuckA is offline
post #4 of 7 Old 10-11-2009
fud
I have a 2GM20F as well. There are no engine zinc's for the fresh water engine, but the raw water version has them. The manual covers multiple versions of the engine and was probably refering to the raw water (2GM20) and not the fresh water (2GM20F).
-- Dave
s/v Glass Half Full
1997 Beneteau Oceanis 281
fud is offline
post #5 of 7 Old 10-11-2009
Cal 9.2 SilverSwan
roline's Avatar
I have the 2GM20 raw water cooled version, 2 zincs. 1 in the block on the dip stick side, just back and above it . The other is on the rear side of the head. They need to be there even in fresh water.
Cal 9.2 #19 SilverSwan
roline is offline
post #6 of 7 Old 10-11-2009
Yanmar Zincs
The raw water cooled version has zincs in the block. Fresh water cooled version should have a zinc in the heat exchanger.
Dream like you will live forever. Live like you will die tomorrow. ( James Dean )
flatracker is offline
post #7 of 7 Old 10-12-2009
fud
BarefootMambo,
As long as you have the 2GM20F there are no zinc's in the engine. It seems this question has come up many times before with the same results of some saying that the Yanmar GM series fresh water cooled engine doesn't have zinc's, and others suggesting otherwise. Check out this thread at the bottom of page 1 and top of page 2:
(There is no) Zinc pencil on Yanmar 3GM30F
There are other places on the internet that say the same thing, but here are the results:
Yanmar uses cupronickel heat exchangers in all the fresh-water cooled GM series and do NOT need zinc's. Then again just try to buy the zinc for a 2GM20F, you won't find it.
-- Dave
s/v Glass Half Full
fud is offline
replacing Yanmar need more power Tequiza Terri Gear & Maintenance 12 10-24-2009 09:30 PM
Shaft Zinc FlySwat Gear & Maintenance 6 06-11-2005 05:15 PM
