Yanmar 2ym15 freshwater drain plug - SailNet Community
post #1 of 4 Old 10-26-2009 Thread Starter
Anyone know how to remove the freshwater drain plug on a Yanmar 2ym15?
Thanks,
Matt
voice3 is offline
post #2 of 4 Old 10-27-2009
Are you referring to the drain on the engine block (located on starboard side, with transmission toward stern)? Or is it a drain on the heat exchanger, etc.
If it is the engine block drain, are you just trying to open it, to drain it, or do you need to remove it (ie stripped, won't close properly, etc)?
Mine is a 2GM, but drain looks the same. Wrench opens it, allows coolant top drain out!
Northeaster is offline
post #3 of 4 Old 10-27-2009 Thread Starter
It's the drain plug midway on the hose coming from the heat exchanger. Its completely round, not a hex head.
voice3 is offline
post #4 of 4 Old 10-27-2009
Sorry, mine is not fresh water cooled-no heat exchanger - can't help!
Do you have a manual?
If not, here is a link to an on-line manual. Click on Yanmar, manuals, marine, ym, etc..
Cascade Engine Center | Diesel Engines | Home
It may talk about it under servicing / winterizing, etc.
Stuck Oil Plug - Ugh Michael K Gear & Maintenance 5 10-03-2009 08:24 PM
Source for Oil drain plug bestfriend Gear & Maintenance 6 01-25-2007 06:40 PM
Universal m35 leak at drain plug sailingdeacon Gear & Maintenance 1 01-07-2005 11:21 AM
Bilge Drain Plug in a Sailboat AJS Gear & Maintenance 3 10-23-2002 08:18 PM
Maintaining Freshwater Kathy Barron Her Sailnet Articles 0 12-11-2001 07:00 PM
