Yanmar 3GM30F - SailNet Community
post #1 of 8 Old 11-18-2009 Thread Starter
Question Yanmar 3GM30F
What should be the compression values of the Yanmar 3GM30F?
aa3jy is offline
post #2 of 8 Old 11-18-2009
I dont have the book with me But I think it was in the 425-485 psi range.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
post #3 of 8 Old 11-18-2009 Thread Starter
Thanks,
Had values of 300, 300 and 250..so I quess those are considered low. Sounds like time for a a refit...Arrrrggggg
aa3jy is offline
post #4 of 8 Old 11-18-2009
I have that engine. compression is supposed to be between 390 and 470. You sound low. Also one of them is significantly lower than the other two. Is your valve clearance what its supposed to be? (.2mm)
sck5 is offline
post #5 of 8 Old 11-18-2009
imagine2frolic's Avatar
Was that done dry in the cylinders?........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
imagine2frolic is offline
post #6 of 8 Old 11-19-2009
It also makes a differance on wether the engine is warm.
dmtjoy aboard SV Pegasus
dmtjoy is offline
post #7 of 8 Old 11-20-2009
Shortman's Avatar
Five years ago my pre-purchase survey for the 1985 3GMF was #1-345, #2-320, #3-380. 320 was considered at the bottom of the range. The engine has run fine (knock on wood) since then. Oil tests come back good.
Shortman is offline
post #8 of 8 Old 11-23-2009 Thread Starter
What page in the Service Manual can the compression values be found? Must be missing something..can't seem to find them...
aa3jy is offline
Replacing our Volvo Penta Engine - Yanmar model? windtraveler Diesel 10 11-25-2010 02:59 PM
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 01:51 AM
Yanmar 3GM30F prop recommendations, please.. mariner3302 Gear & Maintenance 3 08-18-2006 05:15 AM
Prop for Morgan OI w/ Yanmar 3GM30F cwarwick Gear & Maintenance 1 11-16-2004 01:17 PM
