Add fuel sender - SailNet Community
post #1 of 3 Old 11-28-2009 Thread Starter
Add fuel sender
Want to add a fuel sender to a an aluminum diesel fuel tank. Is it ok just to drill into it with a hole saw when there is diesel fuel in the tank, taking care to vacuum up the cuttings as it is being cut with a shop vac so little falls into the tank? Is this safe or will the battery drill motor spark/s or heat from the friction of the drill be unsafe? jeffrey54@comcast.net
Thanks, and happy holidays.
Mystiko is offline
post #2 of 3 Old 12-06-2009
Mechsmith
Drill slowly with a brace and bit. Use grease on the hole saw to keep most of the filings out of the fuel.
Mechsmith is offline
post #3 of 3 Old 12-06-2009
Omatako's Avatar
Use a nibbler
Try one of these if you can beg/borrow/buy one. It will cut the hole without any cuttings going into the tank.
Sheet Metal Nibblers: Manual Sheet Metal Nibbler Shears, Sheetmetal Nibbler
Arthur C. Clarke
Omatako is offline
Which electric fuel pump to add in series on a M5411 crofrog Diesel 13 10-16-2009 11:05 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
