Westerbeke 27 doesn't crank - Page 2 - SailNet Community
post #11 of 12 Old 12-13-2009 Thread Starter
brianontheroad's Avatar
I pulled the injectors and it was wet where the injectors go into the case, but it was diesel, could have been mixed with water but not a major detectable amount....I'd been trying to start it before so I think it was left over diesel from the fuel pump
I pulled the injectors and tried to fill the cylinders with marvel mystery oil through there, I did notice I could get more mystery oil to drain in when I opened the valve for each cylinder - I'm considering having someone hold the valves open while I pour MMO into each fuel injector slot until it back fills, I assume that's the only way I'll know the whole crank case is full??
I should also drain the oil from the oil pan before I do that and then the whole crank case should be full right?
and let that sit for a while and keep trying to turn the motor manually using the nut on the crankshaft pully, I'll probably try and pull the starter in a few days and turn the flywheel manually, but I tried it with the starter yesterday and no joy
other suggestions welcome! Any tips from someone familiar with a westerbeke 27 would be much appreciated
brianontheroad is offline
post #12 of 12 Old 12-14-2009 Thread Starter
thinking about pulling the head and checking the cylinders -- maybe giving the pistons a little assistance from above, the head gasket is still available but no one has the cylinder head bolts westerbeke says it will be 6 weeks to several months until they get around to machining any more
eeek....so in the idea of an expedient end to this problem I don't really want to pull the head, unless anyone has some insight on where I can get cylinder bolts machined? not sure if that's even possible with the specific requirements of engine bolts....or if there's another engine out there with similar bolts I can use?
Brian
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 11 04-19-2012 10:45 AM
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 10:10 AM
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 01:51 AM
Westerbeke Oil Change bossk Diesel 18 01-20-2010 06:48 AM
Westerbeke opinion. maxim_rfeld Gear & Maintenance 3 04-23-2003 05:15 PM
