Winterizing Chespeake Bay - SailNet Community
post #1 of 5 Old 12-27-2009 Thread Starter
I have just purchased a boat in the deltaville area, and wanted to know if it is really necessary to winterize using antifrezze. I was thinking of dewinterizing the motor and just using some space heaters to keep the boat warm.
SqualFrost is offline
post #2 of 5 Old 12-27-2009
Moderator
JohnRPollard's Avatar
Maybe. It's a risk, though.
Up here closer to Annapolis, it would be even riskier. The temps certainly get cold enough to freeze the brackish water. The heater would probably save you -- unless the power goes out.
But if it's already winterized, why not wait until spring?
JohnRPollard is offline
post #3 of 5 Old 12-28-2009
JimsCAL's Avatar
Not sure why you want to dewinterize the engine. Are you hoping to use it over the the winter? Don't like idea of leaving a space heater running unattended. Too many things can go wrong.
JimsCAL is online now
post #4 of 5 Old 12-28-2009
Irrationally Exuberant
I'm with the others--a winterized engine just sits there doing what it's supposed to--not too many worries there. But space heaters running? High mischief potential. Losing power and having the cooling system freeze would be the nicer bad outcome. A wire heating up and shorting and burning down the boat would be the nasty one.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #5 of 5 Old 12-28-2009
Unpaid Intern
josrulz's Avatar
If you're considering using the boat over the winter, here's what we used to do when my family kept a boat in Norfolk. We winterized the head and fresh water, and ran antifreeze through the raw water intake on the engine. When we wanted to daysail, we'd leave the head and fresh water alone. We'd use the engine of course, but then redo the antifreeze on the engine upon return--only took a few minutes. The point being, we still winterized the engine even when we were using the boat occasionally over the winter. Just my two cents...
-J
1984 Sabre 34 Mk I
josrulz is offline
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 130 08-30-2013 11:51 AM
chespeake bay tactics tjerk_hiddes Racing 3 09-01-2002 06:13 PM
Cruising the Bay Islands Liza Copeland Cruising Articles 0 08-20-2002 08:00 PM
Landfall—Glacier Bay, Alaska Liza Copeland Cruising Articles 0 08-17-2000 08:00 PM
Fund Raising and Fun Racing on Tampa Bay Doran Cushing Racing Articles 0 06-15-2000 08:00 PM
