Freewheeling a Paragon Transmission - SailNet Community
post #1 of 5 Old 01-03-2010 Thread Starter
Crew
I've just entered a relationship with a Perkins 4.236 powering a Paragon 400 series hydraulic transmission. The original owner has passed on from this world; not answering any calls, and info on the web is scant re this unit. Any advice on whether I can leave it in neutral, freewheeling, while sailing? Cheers. Bill
clarity36 is offline
post #2 of 5 Old 02-01-2010
I have a Paragon tranny in my boat. It is my understanding that it is better to not let the prop freewheel. If I am not mistaken the tranny oil is pumped only when the input shaft is turning, when it is freewheeling there is no lube oil.
Hope this helps
dmtjoy aboard SV Pegasus
dmtjoy is offline
post #3 of 5 Old 02-10-2010
From my boat club's website:
26.02.05
Our fellow member Dees contacted PARAGON's headquarters in USA and asked them the question of letting or not your propeller to freewheel (As to avoid gear damage). Here the answer from Charles Rother of Great Lakes Power Products:
"IT DOES NOT DAMAGE THE TRANSMISSION TO HAVE THE PROPELLER FREEWHEEL. JUST AS A PRECAUTION, AND YOU PROBABLY DO THIS ANYWAY, THE TRANSMISSION SHOULD BE SHIFTED INTO NEUTRAL BEFORE THE ENGINE IS SHUT DOWN".
Paragon Marine Hydraulic Transmissions
meuritt is offline
post #4 of 5 Old 02-10-2010
Interesting info. I have an older Paragon G35L which I believe is mechanical. I don't let it freewheel, though I suspect a mechanical transmission would suffer no damage.
WanderingStar is offline
post #5 of 5 Old 02-10-2010
Caribbean Surveyor
canadianseamonkey's Avatar
There is a huge discussion on this subject somewhere on this site. There was also a study conducted on freewheeling vs locking to find out which one produced more drag. It was proven that freewheeling produces less drag. The report is also somewhere on this site.
My paragon freewheel all the time, no issues.
canadianseamonkey is offline
transmission question almostbroke Gear & Maintenance 10 09-17-2012 09:56 AM
Hurth Transmission John & Heather Newport 4 01-12-2007 10:09 AM
Transmission Heat Exchanger gconley Gear & Maintenance 7 11-05-2006 09:45 PM
Transmission Engages while in neutral...? kmeeks Gear & Maintenance 1 02-18-2004 09:56 AM
Breakdown in Paradise Mark Matthews Gear and Maintenance Articles 0 04-29-2002 08:00 PM
