Yanmar baffling black smoke - Page 3 - SailNet Community
post #21 of 28 Old 01-27-2010
Did not read the full post ...but whats the air filter / air in take looking like ?
Danny33 is offline
post #22 of 28 Old 01-27-2010
CarelessNavigator's Avatar
Once you have compression established then you can proceed to the next logical step.
You said you have already checked the intake for obstructions also don't forget to take into account leaking pressure on the turbo output. I know you'll have to do that later.
You also said that you checked the exhaust for obstruction and also checked the prop and shaft for drag etc and your results were OK with them. As long as nothing was missed or overlooked and providing the compression is good the next thing is to check out the injector pump. I am assuming everything on that engine is mechanical.
CarelessNavigator is offline
post #23 of 28 Old 01-27-2010
bljones's Avatar
I am surprised at no compression test as well. If the mechanic doesn't have the tools to do a compression test, find another mechanic.
bljones is offline
post #24 of 28 Old 01-28-2010
sigmasailor's Avatar
I read that the nozzles were replaced by nozzles you found on the boat as spare parts. Are these the correct nozzles?
sigmasailor is offline
post #25 of 28 Old 02-19-2010
Before this thread goes into oblivion, I was wondering what was happening? I am sure lots of other people here were wondering the same.
I would like to know the conclusion if or when it happens, not that it is really any of my business but it would be appreciated.
post #26 of 28 Old 08-03-2012
Re: Yanmar baffling black smoke
Hi, reading your 2010 post on your Yanmar headache with black soot.
I have exactly the same symptoms on my Yanmar engine. Spend also a lot of money, with different trials and parts change and nothing has changed.
How have you end of doing for fixing that issue? How was compression test? Thanks for the reply.
Thierry42 is offline
post #27 of 28 Old 08-03-2012
Try to contact Tspringer but I cannot send PM because not enough post replies... Can someone send his a PM in order to get an answer to this thread (inportant for me)?
Thanks.
post #28 of 28 Old 08-03-2012
Señor Member
PorFin's Avatar
Thierry,
Terry Springer hasn't posted here in several years. Reading his later threads about selling his boat, it looks like he replaced the engine with another 4JH4 turbo at some point later in 2010.
PorFin is offline
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 01:51 AM
Gray Smoke -- under load -- Volvo MD2040 hoaga Diesel 5 11-06-2009 09:29 AM
Yanmar YSB8 issues oft Gear & Maintenance 7 09-24-2006 04:49 AM
Yanmar (3GM 20hp) Blue Smoke Problem animaashi Gear & Maintenance 3 11-05-2001 06:18 PM
Yanmar engine startup smoke WillS Gear & Maintenance 4 08-23-2001 04:42 AM
