What do you do to your diesel fuel? - SailNet Community
post #1 of 29 Old 01-30-2010 Thread Starter
Not Finished Yet
RainDog's Avatar
Apologies if this has already been covered, but I have searched the site looking for it and not found anything that satisfied me.....
It seems like adding things to your diesel fuel is pretty much half superstition and half word of mouth.
I am just curious: if anything, what do you all add to your diesel fuel? Also please explain your rationale for doing so. I am not talking about filters, but rather additives.
Thanks,
RainDog
RainDog is offline
post #2 of 29 Old 01-30-2010
No doubt others may disagree but I worked in the petrochemical and refinery business for over 20 years and this is what I do - add cetane booster since all U.S. refineries produce a fuel with a cetane rating less than some engine mfgs recommend.
Keep it fresh and free of water. Anything else just serves to make you feel good.
k1vsk is offline
post #3 of 29 Old 01-30-2010
In boats, the only thing that I do is to add a bit of biocide each fall so that if algae starts, it gets killed quickly.
In my truck and a bunch of other diesel engines that I use through the winter, we use the white bottle of powerservice since it give some cetane boost and helps prevent gelling.
klem is offline
post #4 of 29 Old 01-30-2010
Break, curse, fix, repeat
bwindrope's Avatar
Smile
I burn biodiesel in a ratio that varies between 20% and 60% and so don't have to worry about cetane. I don't know the numbers, but one of the many benefits of biodiesel is the added lubrication it provides. Also don't have to worry about dirty fuel tanks. I polished my tank years ago when I started burning biodiesel and now when I replace my Racor it looks almost new after 100+ hours. I only replace it because I am fastidious about maintenance.
I do add a shot of biobor once in a while for no good reason other than paranoia. I've read enough to think there is reason to fear bacterial growth in the condensation that forms ( I live in the NW where condensation is our middle name) but am not so convinced that I do it with any particular conviction.
Seems the cetane and clean fuel issues are the primary challenges. I'm a big fan of oversized filtration, self-service fuel polishing, and regular filter changes.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #5 of 29 Old 01-30-2010
Hi, I'm a distributor for Syntek Global so this is obviously a little self serving, but take a look at the web site and decide for yourself. This product has been used for over 20 years in industrial diesel engines and only recently been made available for commercial consumption. So take a look, order or not. Just trying to let you know one of your options. Syntek :: Work Hard, Play Hard
RIYachtBroker is offline
post #6 of 29 Old 01-30-2010
Shortman's Avatar
Cetane boost, biocide, & Stanadyne lubricity on the advice of the mechanic that services my trucks (Mitsubishi & Kenworth). He said my 85 Yanmar 3GMF would benefit from the lubricity with the now ultra low sulphur diesel. Maybe it's snake oil but given that I burn 70 gallons in a busy summer and 20 gallons in a not busy summer, seems like cheap insurance.
We did have an injector pump problem in a previous International after the low sulphur came in. Coincidence? Who knows? I didn't think too much of the International anyway.
Shortman is offline
post #7 of 29 Old 01-30-2010
Courtney the Dancer
jrd22's Avatar
I was just told the same thing that Shortman said about the new ultra low sulphur diesel lacking lubricity. I now add Stanadyne as well as the biocide. My mechanic told me that a local water taxi boat doubled the hours between replacing injector tips by adding the Stanadyne, from 1500 to 3000 hours.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #8 of 29 Old 01-30-2010
RTB
TROUBLE
RTB's Avatar
Hey Rain,
I just installed an access port in my tank, emptied all the old fuel, installed a Racor 500MA, new diesel (road diesel from a high volumn Shell station-jug it in), and added this...AmFleet Megatane Diesel Fuel Chemicals & Additives
I can't say if the additive is really needed, but the PO used it.
S/V FUGUE
HUNTER 36
KEMAH, TX
RTB is offline
post #9 of 29 Old 01-30-2010
Ultra low sulfer fuel does have less lubricity. The process of removing the sulfur changes the lubricity, it is not the sulfur itself. There have been some studies done on this and while the lubricity is down, it isn't down much. If I can find where I put the studies, I will try to post the actual numbers. A small amount of biodiesel is probably the best lubricity additive.
klem is offline
post #10 of 29 Old 01-31-2010
Low sulfer fuel ( modern fuel ) does not have the luberication as the old fuel ..we put about a cup of motor oil per 100 gallons of fuel in the trucks up here , some of us , It quites down the top end and gives the diesel more power . If you have an ear for sound ,just try it out and youll know very soon . Injector cleaner is a must ! I been useing Power Service brand for a long time .raises C tane rating and dissipates water in the system .
To me its just part of fuel system maintaince.
Danny33 is offline
Heaters: diesel or solid fuel? Seagypsywoman Gear & Maintenance 9 12-29-2004 02:22 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
