mixing elbow carbon build up - SailNet Community
post #1 of 7 Old 02-02-2010 Thread Starter
I have my Yanmar 2GM mixing elbow apart. I'm wondering if there's a good way to clean the carbon build up from inside the elbow aside from trying to scrape it clean. Some parts are pretty hard to access.
rchad is offline
post #2 of 7 Old 02-03-2010
Not generally worth cleaning it out...generally better to just replace it...
sailingdog is offline
post #3 of 7 Old 02-03-2010
Capnblu's Avatar
Combustion chamber cleaner, may work. At any local auto pars store.
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #4 of 7 Old 02-03-2010
I've cleaned one from a Perkins in a pinch using rotary rasps on a battery powered drill, it took all day and was a PITA.(not to mention it being freakin' environmental disaster)
Rotary Rasps
a grinder may also work, However, the guy at the "old school" Radiator shop I use has a sand and bead blaster and I'll try him if I ever need it done again. Besides the 'hard as a rock' nature of the coke (?) you are trying to remove, reaching far enough in and cleaning smaller water passages are often more difficult.
capnblu's suggestion made me think of brake cleaner which seems like it should break it up also.
"Just call me TB"
capttb is online now
post #5 of 7 Old 03-23-2010
Mark on Camper 58
NICHOLSON58's Avatar
Replace is best and then bust off the big pieces and sand blast it clean in one of those glove-box sand blast units. They are clean, neat and self-contained. Keep it for a spare.
NICHOLSON58 is offline
post #6 of 7 Old 03-23-2010
Don't be so cheap!!! Ask any Yanmar dealer when you are going cruising what should be on the shopping spares list...you will be told a mixing elbow. This should also be on any 10 -15 YO sailboat spares engine list. Don't wait, don't clean it, it will "blow", as it is usually a cast iron piece.
sailor50 is offline
post #7 of 7 Old 03-24-2010
trantor12020's Avatar
Better to replace with new. I tried cleaning mine, chiselling & drilling didn't work an iota. Replacement is the way to go.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
No water coming out of stern scooper (exhaust) stella7maris Diesel 3 09-16-2009 11:53 AM
Carbon Fiber & Lightening Ronbye Gear & Maintenance 19 08-15-2008 04:01 PM
Exhaust mixing elbow I-33 Gear & Maintenance 2 12-02-2006 03:24 PM
New Carbon Fiber Sport Sailboat ?The V38? to Debut in 2007 - E-Composites NewsReader News Feeds 0 09-05-2006 12:15 PM
Tripp design 66' carbon fibre cruiser racer project alajuelacutter General Discussion (sailing related) 0 07-06-2006 11:36 AM
