engine painting - SailNet Community
post #1 of 10 Old 02-09-2010 Thread Starter
Break, curse, fix, repeat
bwindrope's Avatar
engine painting
So my Universal M40 is low hours, runs great and is lovingly maintained on my Gulf 32, and about the only thing I haven't done is to deal with some external corrosion and rust. There is a bit of rust on the coolant reservoir and some chips and rust here and there.
It is not at all easy to degrease and de-dust and completely clean a boat diesel anyway, and prepping for paint sounds absurdly hard. Do people throw on some paint? Do people just spray on Boeshield or something once in a while?
What do people do?
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #2 of 10 Old 02-09-2010
Maine Sail's Avatar
About every 5-8 years I remove any item I can from the engine over the winter, HX, alt, starter, manifold, gear box, brackets, valve cover etc. etc. and bring it home to the shop and completely strip, clean, prime and re-paint each item. Many items I will take to my dads barn where he has a sand blaster as it is just faster and easier..
I then use a dremel with the small scotch brite wheels and other spinning combos of Scotch Brite and brass wheels to go at what is left of the engine with it still in the boat. Usually there are only a few bad spots. I then prime the bare spots and use a liquid sand paper to prep the rest of the engine using microfiber rags for the cleaning and wipe down with liquid sand paper. I then re-install the valve cover and seal off the exhaust and intake ports, seal off the t-stat housing etc. and spray away. I spray in small bursts, take a break, spray, take a break etc. with a box fan sucking out. I always put two 3M pleated home heating system filter taped to the back side of the box fan to catch any over spray. This works well and in combination with the taping and prep I get zero overspray anywhere.
Once the engine is prepped I spend a couple hours masking, taping and getting her ready to accept paint. I then spray on some more factory finish, let cure and re-install everything.
Take your time and she'll look better than those crappy factory paint jobs..
This is what she looks like with 3k hours..
YouTube - Marine Oil Change With Moeller Fluid Extractor Pump
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 10 Old 02-09-2010 Thread Starter
bwindrope's Avatar
OH Jesus Mainesail, my luck you would be the first to reply and set a standard so high it makes any lessor effort seem silly. I literally cannot believe that engine has even been run before, not to mention 3K. Well, for one thing, mine does sit down in a deep bilge area, and although it is up on stringers, it is a collecting spot for all the dust and stuff that can fall or get sucked down through the floorboards. But still, no excuses, your motor is superbly clean.
I don't have that much dog in this race. Having just hoisted her up and replaced all my engine mounts, I have no appetite for any more major surgery, though I don't question for a second the efficacy of your approach.
I guess I am looking for a more, say, temporary measure. She only has 700 hours but is 25 years old (I've had her 3 years and put 300 of those hours on her). A truly beautiful job would require the Mainesail treatment, but in the meantime, any suggestions??
Aeolus
Gulf 32
post #4 of 10 Old 02-10-2010
Rustoleum rust reformer can be painted on rust spots. The rust will turn black. Then use a hi-temp engine paint to touch up. You can clean with a light solvent to pick up grease and oil before painting. Mask off areas and wear a mask for you. Won't look as good as MS but will look better than what you have now. And it will stop the rust from becoming an issue.
xort is offline
post #5 of 10 Old 02-10-2010
Of course, you can actually cook your dinner and eat it off of Maine Sail's engine... Nice job Maine Sail... Beautifully done as always.
sailingdog is offline
post #6 of 10 Old 02-10-2010
Wow, Maine Sail really does this one right. I can testify that not doing it right doesn't get you anywhere when it comes off in 2 or 3 years. I understand that you might not have the patience to take off all the auxiliaries and do a perfect prep job but dealing with rust and grease are imperative to getting the paint to do anything.
There is always the redneck way which would be to paint it with oil, put it in the bed of a pickup and drive down a really dusty road.
klem is offline
post #7 of 10 Old 02-10-2010 Thread Starter
bwindrope's Avatar
Question
I like that redneck way, as it hits close to home for my tribe. I remember the story that Rolls Royce would set out the iron blocks for their motors in the weather for some length of time. Never made sense to me...
Yes, you could eat off of Mainesail's engine. Hell, you could use it as a mirror. Seriously, there is more dust on the motors in the display room than on his. Yikes.
I'm a decent mechanic, and grew up covered in grease helping my (redneck) dad and other family fix and hot rod cars. I know what primo looks like, and it looks like Mainesail's. However, even though I understand all the arguments for a spotless engine, it ain't going to happen this year as the weather has been perfect for sailing here in the NW and spring is upon us.
So in the meantime (where I agree with Jimi H and Buddha, it is the groovy time), I'm looking at something more like the stop gap measure recommended by exort.
I'm still open to products and techniques other than Rustoleum, if there are any other recommendations.
Aeolus
Gulf 32
post #8 of 10 Old 02-10-2010
This is exactly the way I did my Perkins 4-108 last year, although I admire Maine's efforts and apprecaite all of his posts!
lancelot9898 is offline
post #9 of 10 Old 02-11-2010
Mechsmith
The reason for setting blocks out in the weather was to remove the stresses set up in the casting process so that when the block was set up for machineing it would stay put.
International also did(does) it and I suspect most other manufacturers do(did) also.
This is one reason that a good rebuilt motor MAY be better than new.
Mechsmith is offline
post #10 of 10 Old 02-21-2010
Dumah's Avatar
In actual practice a new engine casting MUST be "seasoned" before any machining is done merely to reduce internal stresses from the casting process. Depending on how finicky one is, (I'm not) one can degrease and brush on "tremclad" the engine doesn't care how it goes on just pay particular attention to sheet metal parts, valve cover, side pans oil pans ets, thest parts need protection worse than the block and heads.
Cheers, Dumah, Halifax, NS
Dumah is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
