Transmission used in a 1984 Beneteau first 38 - SailNet Community
post #1 of 5 Old 02-11-2010 Thread Starter
Hi all,
Just wondering if anyone knows what transmission was installed in the 1984 Beneteau First 38. It has the original Perkins 4108 diesel with 4918hrs. Not being familiar with this type of engine, I was also wondering when I would need to consider rebuilding the engine?
Cheers
Fife is offline
post #2 of 5 Old 02-11-2010
Old as Dirt!
svHyLyte's Avatar
The First series drive train of that era where typically 4-108's linked to Hurth 2.1:1 transmissions. If you have the boats HIN number, you can get specifics from Ward Richardson at Beneteau USA (01-843-629-5300).
FWIW...
svHyLyte is offline
post #3 of 5 Old 02-11-2010 Thread Starter
Thank-you so much for the information and phone #. I really appreciate your help!!!
Take care,
Blaire
Fife is offline
post #4 of 5 Old 02-12-2010
Old as Dirt!
svHyLyte's Avatar
You're welcome. The First 38 is an excellant yacht. Andy and Liz Copeland traveled the world in theirs (Bagheera) and she's still going strong with their children now in command. The 4-108 is arguably one of the strongest engines and, with proper maintenance, will run 10,000--and some claim 20,000--hours. They do tend to leak a bit of oil from time to time but that can be limited by keeping the oil level at the mid-point on the dip-stick. For what it's worth, there are more 4-108's running tractors, generators and farm equipment around the world than boats so parts are readily available.
Good Luck!
svHyLyte is offline
post #5 of 5 Old 11-12-2010
The transmission you need is a Hurth 10 with a 2.1:1 ratio.
The tranmission is the weak link in the drivetrain though. The 4-108 at 51 HP @4000rpms is right on the limit for the hurth 10 you might want to install a ZF12 (ZF bought out Hurth) but you will need to move the engine forward or shorten the prop shaft, as the ZF12 has a larger casement.
The Perkins 4-108 is a awsome engine old school tech heavy and strong. However they leek oil from front and rear oil seals. If a perkins stops leeking oil then there probably isnt any left in the oil pan.
robsingham is offline
Beneteau Attitude Suck for You? gtsusa Boat Review and Purchase Forum 10 06-02-2015 10:43 PM
transmission question almostbroke Gear & Maintenance 10 09-17-2012 09:56 AM
Estimating Boat Performance BarryL General Discussion (sailing related) 12 10-22-2009 08:16 PM
Breakdown in Paradise Mark Matthews Gear and Maintenance Articles 0 04-29-2002 08:00 PM
The Beneteau 361 Micca Hutchins Buying a Boat Articles 0 10-07-1999 08:00 PM
