sealing diesel fittings - SailNet Community
post #1 of 6 Old 02-19-2010 Thread Starter
Hello: I think there's a simple answer for this, but I can't get find it in my books or my little chandlery. I have a leak coming off the diesel tank in my 30 Irwin Citation sailer. I suspect it's a very slow drip coming from the brass T-fitting that has a couple threaded couplings. I've tried gently tightening the couplings but it's still dripping about 2 oz. a week.
It looks like there's been some liquid sealer on the couplings. In the house I'd use teflon tape, but on this I suspect that's a wrong choice. Can anyone tell me what kind of goop might help seal those fittings, and whether I can find it at West Marine?
Follow up question... as soon as I disconnect those lines I expect that diesel will flow back out. Is there such a thing as 3/8" or 1/2" bungs that I could temporarily jam into the fuel lines when I take them off the fittings?
Thanks for any thoughts.
30Irwin is offline
post #2 of 6 Old 02-19-2010
Seņor Member
PorFin's Avatar
Standard teflon tape (white in color) is not rated for fuel line connections. Ask the friendly folks at your local hardware store (or Home Depot or Lowes) for natural gas/petrol/LPG rated thread tape (yellow in color). It's usually somewhere close to the gas fittings and/or the propane grill section.
Where on the tank is your supply outlet?
PorFin is offline
post #3 of 6 Old 02-19-2010
I am a big fan of the yellow teflon tape as it has worked well for me. In a pinch, I have used the white stuff a few times and never had any problems.
klem is offline
post #4 of 6 Old 02-19-2010 Thread Starter
ah, OK. This is a big help. Thank you.
Porfin, the tank is in the port settee, all glassed in. It feeds through a fitting near the top on the aft side. It's a bugger to get a good look at through two, small hatches.
30Irwin is offline
post #5 of 6 Old 02-20-2010
Dumah's Avatar
A better sealer is loctite blue, which will allow disassembly. Any teflon tape works, in an emergency,
Cheers, Dumah
Dumah is offline
post #6 of 6 Old 02-20-2010
mitiempo's Avatar
You can combine yellow teflon tape and liquid pipe sealing compound for a good seal.
y
Brian
mitiempo is offline
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Gas versus Diesel Tom Wood Gear and Maintenance Articles 0 01-10-2002 07:00 PM
The Diesel Generator Mark Matthews Gear and Maintenance Articles 0 03-25-2001 07:00 PM
